had an old rev1 with similar problem but not to your extremes,turned out to be a faulty speedo con.rev 1s have a mechanical conection while rev 2s and 3s have electrical.check out japenese f.a.q. on mr2s,may help or just be an interesting read.
as for the unichip you could cut its power supply and the ecu should run off its standard map,if you still have the problem then you will know...!
anything wrong with the spelling then"i dont want to know"(mrsmr2 )
good luck
[Mk2] [Turbo] 0 -100 in 3 secs
ANOTHER
Joey wrote:simmo490 wrote:who said i was talking about KPH, where did this turbo metro club come from??
it is in MPH and that is not the point, the point is i have a problem, hopefully pointing to a badly wired unichip and am seeking advice
andyone over the age of 17 care to help
Hmmmm 0-100mph in 3 secs ?? Can you actually prove this ?
HELLMUTT!!!!!!!
Re: [Mk2] [Turbo] 0 -100 in 3 secs
Some people just don't really read what they're reading do they.
