this correct.
what if i wanted to run low boost for like winter, how would the car run, like crap?
and if i started messing with the hi boost setting, could that screw the map up, or the something?
or is it a case of, if im mapped for 1.2bar, i should only ever run this or less?
i dont mean the map will change, i mean by changing the boost on the controller, could it effect certain components of the car in a bad way?
