Heya people, just wondering if you could answer a quick question for me, my car is in having all the ignition bits changed and I thought I had bought all the bits I needed to carry out the change but my friend rang me up today to tell me he's found the damaged culprit which has been causing my hesitations and miss firing, its the "coil lead" apparently and I hadn't bought a replacement as of yet... so anyway I am going up to Toyota tomorrow and am I right in saying that a coil lead is the same as CORD, COIL RESISTIVE ( part number 19901A in toyota epc and it is also displayed here http://www.ayrpark.plus.com/epc/toyota/ ... 01_19.html
would be great if someone could just confirm but so far this seems to be the only thing I can imagine it could be
Thanks for reading this. Dan
oh ok, well the link is from the mr2 electronic parts catalogue that has a link on this site. Im just unsure whether coil lead is another word for cord coil resistive, just wondering if anyone knew thats all
The part you refer to (Coil Resistive Cord) is the king lead.
Whether or not that's what your friend means is another matter
Ask him if he means the lead that goes from the ignition coil to the dizzy cap.
If you've replaced all the other ignition components but not this then it's certainly worth doing do.
