I know of one person on here that cracked his block but wanna hear of any other horror stories!! If you did, what power was it at? How long did it last? And what was the year of the block???
Thanks,
Nathan
Who has actually cracked their block???
Re: Who has actually cracked their block???
do a search on the american mr2oc.com, there's a post dedicated to it, i remember looking a while ago so should be one there somewhere
Yes us UK boys aren't at the level of the US when it comes to tuned MR2's. Ask over their. There was an actual survey on this on there.
And also speak to Fensport. They have gone few quite a few.
Parts For Sale: KAAZ diff:http://www.imoc.co.uk/forums/viewtopic.php?t=115584 HKS Fuel Rail:http://www.imoc.co.uk/forums/viewtopic.php?t=115585 50mm Wastegate:http://www.imoc.co.uk/forums/viewtopic.php?t=115586
nathanfreke wrote:I know of one person on here that cracked his block but wanna hear of any other horror stories!! If you did, what power was it at? How long did it last? And what was the year of the block???
Thanks,
Nathan
Its happened to a few rev3's running 300-330 bhp. V8Killer here was unlucky enough to have that problem. Rev1 and Rev2's have a different cast block and don't seem to have a similar issue.
BenF wrote:nathanfreke wrote:I know of one person on here that cracked his block but wanna hear of any other horror stories!! If you did, what power was it at? How long did it last? And what was the year of the block???
Thanks,
Nathan
Come on Ben. Didn't you read my posts in the other threads?
The US boys are cracking blocks from all revs at anything over 400hp. So the early revs do seem to have that problem.
I cracked mine at less than 400bhp.
Forever Feels Like Home, Sitting All Alone Inside Your Head...
Damn! Hope my Rev2 will be ok pushing about 380@fly. Kept it instead of switching to a Rev3 'cause I hear the blocks are *generally* a little stronger. Guess I'll find out soon
[SiG] wrote:Damn! Hope my Rev2 will be ok pushing about 380@fly. Kept it instead of switching to a Rev3 'cause I hear the blocks are *generally* a little stronger. Guess I'll find out soon
I think that'll be ok mate.
would be interesting to see out of those that have cracked, if they had the block bored out or was standard bore
ENSMR2 wrote:I think that'll be ok mate.
Any chance of a guarantee?
Kept mine as standard bores too, for safety more than anything
[SiG] wrote:ENSMR2 wrote:I think that'll be ok mate.
No chance mate lol.
A guy called Tristan did a lot of work on finding what the problem was. Have a search on the US OC and you'll find it/
Jay, the US lads listed up all their mods when they stated whether or not they had cracked their blocks. Have a search and see.
Cheers Ens, some good threads over there
Cracked mine at less then 400BHP too...infact only about 320 odd BHP!!!
M5
Rev3 wasn't it m8? Damn some of them blocks are fragile
Am just hoping my Rev2 will take 380-385@fly, should do
Spec below if anyone's interested;
Rebuild with forged pistons & everything else needed
T3/T4 Turbo Stage3 (still pondering this atm, have to replace my ct20b tho)
HKS 256 Inlet Cam and pair of Cam Gears for adjustments
ATS Fuelrail, uprated fuelreg and 540cc injectors
Berk IC and Paul Port programmable Water Injection system
And some other bits like RPS 6-puk clutch etc
V8Killer wrote:Cracked mine at less then 400BHP too...infact only about 320 odd BHP!!!
what have you gone with this time round mate?
Very interested in this thread. I'm building a 400bhp rev 3 based engine with a .5mm overbore.
Off to the .com boreds to do some reading then [-o<
Spacey wrote:Very interested in this thread. I'm building a 400bhp rev 3 based engine with a .5mm overbore.
I wouldn't over bore a stock block.
Mushin, Neil. What size pistons did you have?
I was speaking to Tony at Fensport and he said you shouldn't bore it out to fit bigger pistons as you are making a weak block weaker. They had problems running 87mm pistons (with a stroker kit) on a thickwalled block. Thats why they went down to 2.1 (going from 87mm pistons to 86mm).
I wouldn't go bigger pistons on our blocks. From what Tony was saying. 87mm pistons or 86.5 are ok on thick walled blocks but when you go stroker on a thick walled block is when you get the problems on them. Should have got a kit where the 2.2 is all in the stroke (like mine )
Stock blocks I'd go stock size pistons.
Or get a thick walled block like I have
or cheaper and stronger than a thickwalled block get a sleeved block like i did
i agree on the overboring, that's why i sleeved mine, not too keen on the idea of wekening mr2 blocks that are knwon to crack
ENSMR2 wrote:Spacey wrote:Very interested in this thread. I'm building a 400bhp rev 3 based engine with a .5mm overbore.
My good mate Nick has been running 87.5mm pistons for 40k miles on his rev 2 it runs at 1.5bar and is producing 350 bhp on standard rev 2 injectors and ecu
Watch out OZ here I come !!
screech wrote:or cheaper and stronger than a thickwalled block get a sleeved block like i did
Yes.
I would only go to one guy to sleeve a 3s block. Only problem is he is in the US lol
