hi
i need to replace the drive for the power window ( drivers side if it
makes any difference ) on an E reg 1998 totyota mr2 mk1 .. the manual
skirts round this issue
is there anything on the web / do you have anything that may help (advice or pictorial )
any help would be greatly appreciated
regards mike burr
[email protected]
WINDOW PROBLEM
Re: WINDOW PROBLEM
get one of the CD discs of ebay much better than Haynes
Re: WINDOW PROBLEM
If it is the motor you need to replace have a look at this
http://www.twosrus.com/instructions/MKIgear.PDF
If it is the full mechanism read this
http://www.mr2mk1club.com/repairsp24.html
I replaced the full mechanism on my passenger door a couple of weeks ago, it is a bit of a PITA but with perserverance it is fairly easy.
