Tony jinxy froude wrote:Ok Guys here goes, Kev Crane and myself have an early MK1 with a problem, we have changed ECU's, ENGINE WIRING LOOM, THROTTLE BODY,& TPS SENSOR, but to no avail, when we short out T& E1 with the ingnition switch on
only
, we get 1 flash on the dash i.e normal, when we start the car
WITHOUT
touching the throttle we get a fault code 11 flashing on the dash, this causes the timing to advance/retard making the car run awful, we have even adjusted the TPS using the BGB, feeler gauges and a meter with everything reading as it should, we even checked this on my own car, with engine running and diagnostics shorted out
= code 1 hold the throttle open
= code 11, return to idle
= code 1.
Our other car will only return to code 1 if we pull the AM2 fuse to reset the ECU even without the throttle being touched
?????, anyone have any idea's as this is driving us really barmy and men in white suits are not far off i fear, cheers, Jinxy[/u]
Tony jinxy froude wrote:Yep, we sorted it guys, it was a bloody cold day to get your brain working but we did it in the end..
YIPPEEEEEEE
!!!!!!!!!!!!!, Jinxy
crazylegs wrote:ok the replacement tps was adjusted we spent ages with it off the car with feeler gauges and multimeter untill it was spot on.but forget all that,just do it by hand approx and fine tune with the stop screw.but that is all hindsight.
the problem was the distributer had been used to compensate for the tps not working
.so with a strobe it looked close enough to normal.
the ECU was throwing up a tps fault code because it was seeing the advance and assuming it was the tps that had malfunctioned even when we had replace the faulty unit.on top of that the idle adjustment had been used to prevent the engine stalling so the idle was way out.the map sensor was also totally off.the previous owner or someone for him had forced the engine to run with the tps not working at all.they had altered the distributer to negate the tps problem.
the ECU was seeing the faulty tps as being at the open position and was adjusting the timing for high revs.the distibuter was miss adjusted to bring this back to enable it to idle normally.its a wonder and a testament to toyota that the engine ran at all
this is the short version of a very gruesome tale
