engine swap!!! n/a to turbo...advice please!!
Ryan S
Post by Ryan S »
just about to pick up a turbo engine. it will come with the starter,turbo and all hoses and intercooler, alternator, wiring loom, ecu, fuel pump but no gearbox or drive shafts, anything else i need and how will my box and shaft :oops: hold out?????
cheers!!!!
GeoffC320
Re: engine swap!!! n/a to turbo...advice please!!
Post by GeoffC320 »
sheppy wrote:but no gearbox or drive shafts, anything else i need and how will my box and shaft :oops: hold out?????
cheers!!!!
They will be fine...as soon as you swap them for a turbo 'box and shafts.
I believe the N/A components are not in anyway compatible with the engine...doubtless someone will be on to confirm in a sec... 8-[
cantfindausername
Post by cantfindausername »
I would say they are not. I've held a rev1 n/a box, and a rev2 turbo box in my hands, and they are very different beasts.
***RIP Car13 ***
*** Now in an Evo ***
Ryan S
Post by Ryan S »
what about rev2 n/a box???if the engines are essentially the same why would the box not fit???
^Trickster^
Post by ^Trickster^ »
The na box and shafts will fit, but wont last very long at all.
Get a turbo gearbox and drivshafts and hubs (or just the collars to go into the hubs will do, get them pressued into your na hubs)
contact gtschris on [email protected] he had a good gearbox last time i was there, im sure he would have shafts and hubs to do you a deal on.
The na box is tiny compared to the turbo box physically, but the do bolt up to the block the same.
Edit, all turbo revision boxes are interchangable with all revision engines, all the castings are the same, only difference is with lsd and non lsd in the turbo, and the obvious na box/driveshaft are totally different to turbo box/driveshaft.
Graeme
Ryan S
Post by Ryan S »
thanks for that mate, just what i needed to hear!!!
i'm just gonna take it easy till i get all the right parts!!!
theres a guy on the board who has the lot and if he can get in touch with me by 8am i'll go pick up the whole lot!!!
cheers again!!!
sorry just to clarify will i deffo need a new box too???
^Trickster^
You want a turbo gearbox and driveshafts and hubs.
The hubs themselves are actually the same, but the collar or spline whatever you like to call it, that fits into the hub bearing, then which the driveshaft connects to is bigger on the turbo shafts, what i have done in the past is used the hubs from the na (which are no stronger or weaker than the turbo, just exactly the same!) and pressed out the spline/collar and pressed in the turbo ones to accept the turbo driveshafts.
Good luck
Graeme
Ryan S
Post by Ryan S »
so i can just dump the turbo engine in just now to get the car on the road??
as i said i'll be taking it easy in the meantime
dai21t
Post by dai21t »
You'll have to fit the NA flywheel if you're using the NA box and clutch. Different diameter clutches and the turbo input shaft is bigger diameter as well.
