costs about 225+vat from another place, which is a lot cheaper than sleeving a block which costs 1.5-2k
(obviously it won't be as strong but it's still a good option).
used for all sorts of things including motorsport
"Cryo treating completely stress relieves the block and actually strengthens it by increasing the amount of martensite
(a hard crystalline variant of steel) carbide inclusions within the metal.
It also rearranges the metals molecular structure into a better symmetrical crystal matrix with more complete molecular bonds that further helps strengthen the block.
These microscopic changes also increase abrasion resistance and the lubricity of sliding surfaces, thereby reducing friction.
You can expect much longer wear of the cylinder bores as well as improved dimensional stability under all conditions.
The improved dimensional stability improves head gasket and piston ring seal.
Cryo-treated blocks can make up to 6 percent more power just due to better ring sealing and less internal friction alone.
In many ferrous metal applications, cryo treating can increase wear resistance by over 800 percent, fatigue strength by over 100 percent, and tensile strength by up to 25 percent.
The typical increase of wear resistance in cast iron like our block is 100 percent.
__________________
