K&N panel filter, don't go down the cone route, you need the resonator box for maximum torque
(which is reasonably high on this engine)
Run it on Optimax and advance the timing to suit.
Don't fit any accessories or carry passengers, if you've got a spoiler lose it, adds weight and drag that you can't afford.
Go out and play with the gear ranges, you may find that changing at around 5750 mark gives best performance, power tails off to 6300 quite quickly.
It's never going to be a traffic light GP car, but once rolling you can get these to move quite nicely, should keep a GE in it's sights on a country road.
