50mm lowering springs for the rear [any chance]
is it possible to get 50mm rear springs for a rev 2 turbo,is there a chance or not,any help?
Re: 50mm lowering springs for the rear [any chance]
If you are looking at more than a 40mm drop realistically you'd be better off looking at coilovers.![](./images/smilies/spacer.gif)
For a 40mm drop try Tein or PI lowering springs for best combination or drop and ride quality.![](./images/smilies/spacer.gif)
For a
<40mm drop try the Tein coilover sets.![](./images/smilies/spacer.gif)
HTH
For a
HTH
JUIC'IN wrote:If you are looking at more than a 40mm drop realistically you'd be better off looking at coilovers.
For a<40mm drop try the Tein coilover sets.
i already have a 40mm drop all round,but the rear is always that bit higher,hence 50mm rear set,i know its probably impossible but im sure someone makes a set
i already have a 40mm drop all round,but the rear is always that bit higher,hence 50mm rear set,i know its probably impossible but im sure someone makes a set[/quote]
[/quote]![](./images/smilies/spacer.gif)
