Jay
Al-sw20 wrote:I dont know what the limit is in mph/km/h but it seems to be 5500rpm in 5th and a tad before redline in 4th.
BTW who is silly enough to pay for a speed delimiter when you can get a 1 quid interconnect from a electronics store that will do the same thing?
Jevansio wrote:I've just sold my speed delimiter and noticed for the first time it says it's a 200 kph speed jumper, this equates to 125 mph.![]()
Now I know it's common knowledge that the limit is 112 mph, but a lot of people say that theirs go past 112 mph and seem to cut at about 125 mph, is this just a coincidence that that's what is plastered on the side of the Blitz Speed Jumper or could the real limit be 125
Jay
Al-sw20 wrote:Quite simple, its not a required wire for the ecu to operate.![]()
You need a CMOS 4024 Bin Counter 7-Stage, should be cheap as at an electronics store.
The i/c connects in this fashion
Pin#1
-> Speed Input
( From Speedo
Pins# 2
#7
-> Ground
Pin#14
+5v
Pin#12
-> Speed output
(to ECU)
Al-sw20 wrote:You take the speed signal from the ecu.This has been done over here a few times by various owners.
Al-sw20 wrote:Yeah that sounds like the one, the purple wire with a white stripe.You just put the i/c on the speed input wire to the ecu
