[Mk2] [NA] Immobiliser/ key transponder bypass
Lee8ballauto
Post by Lee8ballauto »
Right long story short I bought an engine and ecu etc to transplant my blown rev1 n/a to a rev3 n/a, when I bought the engine I was told it was from a 94 car but it has an egr valve and a 4-1 manifold which seems to put the engine at 96-97 now the 96-97 cars have a transponder to pick up a chip in the key to de immobilise it I don't have the transponder the key or anything similar to that and my car being rev1 doesn't have it so how do I get round it can it be bypassed somehow just so I can get my car running? Obv reply via pm if you know how to do it.
Chris
Re: [Mk2] [NA] Immobiliser/ key transponder bypass
Post by Chris »
You will need the immobiliser ecu box, and key reader at a minimum. I managed to wire a car using just them, and not the key. Ideally you need the key also.
Without them, I think you are screwed. I tried a few ecu placed to see if they could remove the immobiliser side to no avail.
Lee8ballauto
How do I wire it into the rev1 loom though? And where is the transponder box?
Chris
Post by Chris »
You need the Rev 4 engine loom, the immobiliser box is behind the drivers seat in the a post iirc. Rev 4 are 4 plug, rev 1 3 plug ecu so cannot fit the ecu to an early loom.
You can run the later engine on the rev 1 loom and ecu, but they tend to run crap.
Lee8ballauto
I have the rev4 engine loom fusebox ecu and the loom that runs to pass footwell but none of that would go to drivers side:s
Chris
Post by Chris »
You don't need the loom as you can wire it at the ecu instead. But you need the immobiliser ecu, and reader from the ignition barrel of the rev 4. The car I wired in ran without the key. Might of been a faulty immobiliser ecu though so cannot guarantee it will run without the key.
Basically, you wire the immob ecu, key reader etc at the ecu. And tape the key to it if required.
Lee8ballauto
Ok thanks is the immobiliser ecu box labeled with anything in particular just so I can check if the guy still has it etc?
Shenrog
Post by Shenrog »
Chris wrote: Wed Feb 01, 2012 9:37 pm
hello i'm now on exact same situation . mk2 91 car no immo from factory . swap gen3 3sge ecu engine fuse box wires. do you now how to wire immo box to ECU ? or maybe just pins from engine Ecu side thats going to immo box ? there is no immo in /immo out like on other toyotas. i cannot find any information about it. thankyou.
jeffmr2oc
Post by jeffmr2oc »
Return to “Electrical”
