Paul Woods had told me that Fiesta links were the correct length for the front, just needed a small modification and could be easily modified to suit the rear.
A visit to eBay got me 4 of these for
One pair were easily modified to suit the front by heating the rod and twisting one end round until both joints were facing the same way
Here's a comparison with a original Mr T link, the Fiesta ones are almost identical, the only difference I could find is that the rod part is 1mm thicker than the original.
The other pair were modified to suit the rear by cutting and shortening to the correct length, then sleeving and welding the rod
I managed to get 3 of the links off without much problem, but the last one needed the attention of the angle grinder
While I had them off I decided to remove both ARB's and give them a clean and paint as they were extremely rusty.
Here's the rear bits ready to go back on
Rear drop link refitted
And the engine mounts refitted
Front links and ARB refitted
Clunk is now gone, there was one link away at the front and 1 at the rear.
Oh and the car sailed through the MOT
Jimi
