JDM Import Rev 2 Turbo - 5SGTE build
rossonza
Premium Member
Re: JDM Import Rev 2 Turbo - Megasquirt install. Anti lag. 2 step.
Post by rossonza »
Ryan S wrote:Ah well, Used but near new. Got them off a guy breaking one. It's 100% the windows. They are really loose. Wobble about when i have them down haha!
thats what mine does, due to that white triangle plastic wedge missing in the above photos... are both of yours present?
Ryan S
Post by Ryan S »
I've not actually looked!! I've had the doorcards off recently too. In all honesty if you never mentioned them I wouldn't know they were supposed to be there!
rossonza
Premium Member
Post by rossonza »
Well ive had a few days off work so i installed my boost control circuit on megasquirt, i then installed the MAC solenoid and configured it all:
13/14psi is a noticable difference from the usual 10psi.I did notice my stock turbo runs out of steam ~5k rpms, so boost tails off. good job ive got that new better turbo to go on. either way I'm happy to finally have my electronic boost control working.
I'm also building a bluetooth serial adapter for megasquirt, and then because my cars radio is an android headunit i can install the megasquirt android app and tune/make changes from my radio touch screen which should be cool.
also ordered all new speakers, try and get some nice sounding music in the car, enjoy it a bit more. still need to source a quieter exhaust though.
rossonza
Premium Member
Post by rossonza »
well i had planned to buy an exhaust off a member on here, but theyve since gone awol. So ive bitten the bullet and im going full custom stainless setup on Wednesday.
something similar to the below. So ill be selling the Apexi GT shortly which should hopefully cover some of the custom exhaust work.
Ryan S
Post by Ryan S »
Oh those are great sounding exhausts! The N1 also sounds amazing!
rossonza
Premium Member
Post by rossonza »
Ryan S wrote:Oh those are great sounding exhausts! The N1 also sounds amazing!
its just too loud for me :-( i must be old.
Ryan S
Post by Ryan S »
they are extremely loud haha!
rossonza
Premium Member
Post by rossonza »
Well the exhausts done. And I'm well happy. Not too loud and not silent. Definitely a sporty sound and also glad I kept it 3" entirely
Will try and get videos tomorrow/next week.
androo007
Post by androo007 »
your sump looks very weepy
rossonza
Premium Member
Post by rossonza »
androo007 wrote:your sump looks very weepy
It's excess oil from my cam cover leak. I havnt had time or the weather on my side to jack it up and clean it all off. :thumleft:
rossonza
Premium Member
Post by rossonza »
Well the last few weeks I've been purchasing loads of rev 3 engine bits ready for my forged build. Still waiting on a few bits but im getting there. I've basically built an entire gen3 engine from parts.
Also had some more car presents arrive :-)
Full engine gasket set
Toyota Oil Pump, Aisin Water pump/pulleys and HKS fine tune cam belt.
AN12 fittings my friends sorting to be welded onto my rev3 rocker cover.
Rev 3 Head
just waiting on throttle body and need to collect crank/sump setup/oil cooler and water pipework from my mate Chris.
need to buy a clutch as well. anyone recommend anything for up to 400hp?
then its send block/crank/bearings/studs off to get built up. :thumleft:
Ryan S
Post by Ryan S »
i have a clutch masters FX400 in mine. Feels just like the stock clutch and is rated to 500bhp. over 4000 miles without issue so far.
rossonza
Premium Member
Post by rossonza »
Ryan S wrote:i have a clutch masters FX400 in mine. Feels just like the stock clutch and is rated to 500bhp. over 4000 miles without issue so far.
Ok cheers dude. Been recommended exedy stage 2 also. So I'll have a look into both.
My mate Ian made a sleeve for my an fittings to fit his lathe so he didn't damage the threads. He then turned down some of the metal and got them welded to my rocker cover. I'm chuffed
Think I'm going to black crinkle.paint the cover (once I've cleaned it lol)
Ryan S
Post by Ryan S »
Looking great dude! I've had 2 exedy clutches break one me just FYI. Just single plate ones but I'll never use them again. Broke right at the spring retainer.
rossonza
Premium Member
Post by rossonza »
Ryan S wrote:Looking great dude! I've had 2 exedy clutches break one me just FYI. Just single plate ones but I'll never use them again. Broke right at the spring retainer.
hmmm ok good to know. :thumleft:
rossonza
Premium Member
Post by rossonza »
Well got my full sump setup, crank, water filler neck, oil cooler and all associated oil/coolant pipework oh and exhaust manifold/adapter plate and dump pipe from my mate chris.
ryan got me my throttle body so im nearly all sorted for the entire engine. just got to find the following:
1. Crank pulley damper (is rev2/3 the same?)
2. Lower cambelt cover (has the timing marks on it)
3. Upper rev2 cam plate (what the upper cover attaches to)
4. engine hooks (is rev2/3 the same?)
5. rear end plate sits behind the flywheel. )page 99 here
- http://shinny.co.uk/toyota/RM398E.pdf
6. dipstick and guide
Also need to figure out if i can use my alternator bracket and alternator off my rev 2 turbo engine.
engines with the machine shop right now, so waiting to get my hands on it early next week hopefully. :thumleft:
Equium Duo
Post by Equium Duo »
Dude I am missing that rear end plate, found someone in the states on facebook but it was $20 for part and $30 shipping. Can put you in contact if you don't get any luck in the UK. I haven't had luck finding any on ebay though.
Are you attaching a crank trigger wheel?
rossonza
Premium Member
Post by rossonza »
Equium Duo wrote:Dude I am missing that rear end plate, found someone in the states on facebook but it was $20 for part and $30 shipping. Can put you in contact if you don't get any luck in the UK. I haven't had luck finding any on ebay though.
oh nice good to know! thanks!
im sticking with distributor for now, i had read COP just tidies up the bay/isnt really required until your over 7/800 or so HP.
my friend Chris has a full COP kit with trigger wheel attached to a damper but ive decided against it for now.
ive since managed to source crank pulley damper and dipstick setup.
Ryan S
Post by Ryan S »
You can take signal right from the dizzy for COP. That's how mine is set up. The issues I've have with coils/igniters/dizzys and ignition leads in the past I was certain I wanted to make the change. Not a big job at all but as you said not necessary until silly power.
rossonza
Premium Member
Post by rossonza »
grabbed one off ebay for £30 posted. had the other part attached to it too (rear end plate no2)
