After months of no power steering, I've decided to finally try and fix the issue.
For some time, the ps just wouldn't turn on what so ever even after checking continuity in the ps systems and trying the relay trick many times.
After letting my mechanic have a little look at it, it will now turn on when the car starts and turn off after a couple of seconds.
I've tried following the self-diagnostic as per the BGB and struggled to get a fault code but the light would just flash continuously.
I am running out of patience and considering removing the ps rack and making it a weight saving modification but of course, I would rather fix it.
Has anyone experienced this issue before and can shed some light on a fix or some ideas on what I could try to help narrow the fault down.
All help will be much appreciated.
Many thanks
93 Mk2 Rev2 Redtop beams
(From Celica gen 6)
- Power steering system is all original and has not been altered.
