Must say, I think given the space you have there and the fact that you don't want to retain function.
.definitely simpler in the long run to remove the pump and the front condenser rad.
You would probably spend as long pulling the pulley off as you would just unbolting the lot and dropping it down.
As it's a clutched pulley I can't see it just falling off once you've removed the faceplate bolts.
