All of those have been verified.
I use spherical bearings instead of brass bushes, and the slave and main are quite new.
Also i didn't touch anything
, except the bush.
I suspect that the problem may have been introduced by the mistake i did to only polybush the front one.
The engine seems to jump quite violently in the bay.
Anyway i noticed i cannot engage the gear also while in neutral.
If i try to engage, it simply does not go in.
If i go through another gear it goes in, but not always sometimes i'm still blocked, so it looks like something inside the box may have been damaged, but its very strange that there are no grinding noises.
It simply refuses to go in.
I can feel the cables trying to bend slightly
,if i push too hard, but the gear does not go in.
Its as if there is a wall there.
Anyway its 4th gear, so no big deal for now, probably will drive like that for a while, until i decide to open the gearbox.
