OEM discs and pads or at least a quality brand OEM equivalent.
Brembo, Pagid, Mintex etc.
If you want lower dust then EBC red stuff increase the stopping power and are lower dust pads BUT.
Ideally you better results with the red stuff pads if the discs aren't brand new.
So you could buy some cheap pads and new discs then once they're bedded in switch to the red stuff pads and follow the bedding in procedure.
Unless you really push the the car OEM or equivalent should be enough though.
Some thing else to consider is a brake fluid flush if it hasn't been done in the last 3 years.
Also if you want a firmer pedal then braided hoses will make a massive improvement on the old rubber hoses even with OEM discs and pads.
