yokomomr4bx wrote:The only other thing I can think of is water collecting around the connector between the coil and the primary lead, bit of a dead spot for water dripping down, but if that were the case I would expect it to cause issues after every rainfall.
I agree, if it was water related you'd normally expect the same problems every time after heavy rain, as can be the case when the outer plastic is cracked on the coil.
If you continue to have problems, it might be worth starting the car after dark as any possible tracking issue on the ignition leads etc should be clearly visible.
I did have one set of aftermarket leads where I found the wire was a poor push fit the the plug cap
- just pulled out without any effort at all.
yokomomr4bx wrote:PS.
On a side note, does anyone happen to know what circuit these two capacitors are associated with?
I'm afraid not.
I believe those are decoupling capacitors just used to suppress
"noise" on the power supply to the ICs, so when they fail the ECU would probably continue to function without them, unless you were unlucky.
The real issue is the damage the gunk that comes out of them can do to the tracks on the circuit board.
Which is why it's always a good idea to make sure to remove any traces found.
I first hit this issue when I pulled away, and within a few hundred yards the engine management light started randomly fading in and out, even though the car seemed to be running OK, I returned home straight away as I didn't fancy pushing my luck to see if I could find if anything had actually stopped working
When I opened up the ECU the adjacent tracks were in a real mess.
So bad in fact that I didn't even bother trying to bridge the damaged sections and started looking around for a replacement.
When a replacement turned up the first thing I did was to open it up to check the capacitors.
Luckily one of them was only just showing signs of leaking and the gunk hadn't reached the circuit board yet.
Needless to say I replaced both to be on the safe side.
