Turbo is a CT26 Hybrid of some sort on a Gen3 3SGTE.
With the stock TVSV, it would peak at 14psi or so at most and then drop down to around 12.5 to 13psi and taper off.
With the boost controller now connected it's hitting 16.2PSI with the boost controller set value set to 0%.
What could cause this?
