Would it be useful to have a thread which lists all the parts which are known to be discontinued?
I did have a quick search but couldn't find one.
I found out this week that the gasket between inlet pipe and the throttle body is discontinued. I suppose maybe somebody somewhere may have some on the shelf but asking my local dealer they say discontinued.
To start off:
17376-88380 Inlet Pipe to Throttle Body Gasket
Discontinued Parts
Discontinued Parts
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
Re: Discontinued Parts
Problem is my local dealership say most things are discontinued then i find i can get it elsewhere lol
HKS SW20 264 Cams unable to get from HKS Japan and Europe. .
MartinF wrote:I found out this week that the gasket between inlet pipe and the throttle body is discontinued. I suppose maybe somebody somewhere may have some on the shelf but asking my local dealer they say discontinued.
What you tend to find, or at least I do anyway, is that most of the original part numbers are discontinued but some have just changed number.
Steering fogs are discontinued, standards are still available.
might be of help to you guys in this regard...
http://www.mr2forum.de/index.php/Thread ... post864428
'Access Denied'
Blue Lexus RCF
Damn Oh well here goes then...
33481-17011 Gear speedometer, drive (Tachowellenantriebsrad am Differenzial)
11355-74030 Plate rr end no 1 (Halteplatte KW-Simmerring Getriebeseitig)
16268-88382 Pipe water bypass ( Kühlmittelrohre unterm Krümmer)
91611-b1028 Bolt (Schraube)
82661-17110 Cover relay block (untere Abdeckung Sicherungskasten Motorraum)
82661-17181 Cover relay block (obere Abdeckung Sicherungskasten Motorraum)
90980-10354 Housing connector (Steckergehäuse Stecker drittes Bremslicht)
90980-10819 Housing connector (Steckergehäuse Stecker EA1 am Karosse-Kabelbaum zum Sicherungskasten Motorraum)
69005-17111 Cylinder set lock w. power window (Schlosssatz)
68111-17030 Glass sub-assy, front door RH *TT,T 5.0, blue (Seitenscheibe rechts 5% Tönung, blau)
68112-17030 Glass sub-assy, front door LH *TT,T 5.0, blue (Seitenscheibe links 5% Tönung, blau)
77001-17905 Tank Assy, Fuel (Kraftstofftank)
88267-17030 Bracket, Skid Control Computer NO.1 (Halterung, ECU ABS Nr. 1)
88268-17030 Bracket, Skid Control Computer NO.2 (Halterung, ECU ABS Nr. 2)
89541-17010 Computer Assy, Skid Control (ECU ABS)
78024-88382 Bracket Sub-Assy, Accelerator Control Cable (Halterung, Bowdenzug Drosselklappe)
78180-17180 Cable Assy, Accelerator Control (Bowdenzug Drosselklappe)
78180-17210 Cable Assy, Accelerator Control (Bowdenzug Drosselklappe)
78183-17050 Clamp, Accelerator Control Cable (Halteklemme Bowdenzug Drosselklappe)
78113-17020 Cover, Auto Drive Accelerator Link (Abdeckung, Tempomat Umlenkung)
78100-17050 Link Assy, Accelerator (Tempomat Umlenkung)
90249-08116 Pin (For Accelerator Pedal) (Stift Achse, Gaspedal)
78120-17040 Rod Assy, Accelerator Pedal (Gaspedal)
90506-08019 Spring, Tension (For Accelerator Link Rod) Production Date: 01/1990-03/1990 (Zugfeder, Tempomat Umlenkung)
90508-10063 Spring, Torsion (For Accelerator Link) Production Date: 01/1990-03/1990 (Druckfeder, Tempomat Umlenkung)
90959-01399 CLAMP (Schelle)
90201-08076 WASHER, PLATE (Unterlegscheibe)
89170-17010 Sensor Assy, Air Bag (Steuerungseinheit Airbag)
17705-74100 Cap Sub-Assy, Air Cleaner (Abdeckung obere, Luftfiltergehäuse)
17700-74310 Cleaner Assy, Air (Luftfiltereinheit)
17861-88383 Connector, Intake Air NO.2 (Anschluss, Ansaugrohr Nr. 2)
17341-74180 Hose, Air, NO.1 (Schlauch, Luft Nr. 1)
17940-74040 Intercooler Assy (Ladeluftkühler)
22250-74220 Meter Assy, Intake Air Flow (Luftmengenmesser)
17875-74100 Pipe, Intake Air Connector (Verbindungsrohr, Ansaug)
17783-74030 Plate, Air Cleaner Baffle (Halterung LMM an Luftfilter)
53298-17020 Retainer, Cool Air Intake Duct, NO.3 (Halter Ansaugkanal)
17871-88381 Stay, Air Connector (Halterung Drosselklappengehäuse an Zylinderkopf)
17368-88380 Support, Air Tube (Halterung Ansaugrohr "Hotpipe")
17364-88380 Tube, Air, NO.4 (Ansaugrohr "Hotpipe")
90109-06229 BOLT (Schraube)
90540-11012 CUSHION (Gummischeibe)
90560-07024 SPACER (Abstandshalter)
27039-42020 Cover, Alternator Rear End W(POWER STEERING) Production Date: 01/1990-05/1991 Replaced by: 27039-50080 (Hintere Lima Abdeckung)
27039-61250 Cover, Alternator Rear End W(POWER STEERING) Production Date: 10/1991-01/1992 (Hintere Lima Abdeckung)
27039-74170 Cover, Alternator Rear End W(POWER STEERING) Production Date: 05/1991-10/1991 (Hintere Lima Abdeckung)
27357-50030 Holder, Alternator, W/Rectifier W(POWER STEERING) Production Date: 01/1990-05/1991 Replaced by: 27357-50060 (Gleichrichterplatte Lima)
27357-50060 Holder, Alternator, W/Rectifier W(POWER STEERING) Production Date: 05/1991-10/1991 (Gleichrichterplatte Lima)
86300-17100 Antenna Assy, W/Holder MOTOR (Antenneneinheit mit Motor)
86300-17110 Antenna Assy, W/Holder W(REAR SPOILER) (Antenneneinheit mit Motor - wenn Spoiler vorh.)
67625-17040 Bracket, Door Trim, NO.1 LH Location: Passenger Side Production Date: 01/1990-11/1991 (Halteplatte Türgriff Nr. 1)
67626-17030 Bracket, Door Trim, NO.2 RH Location: Passenger Side Production Date: 01/1990-11/1991 (Halteplatte Türgriff Nr. 2)
74633-17010-02 Cap, Coat Hook RED,TRIM3# (Abdeckung Kleiderhaken, rot)
74610-17020-02 Grip Sub-Assy, Assist RED,TRIM3# (Griff, Einstiegshilfe rot)
74814-17010-04 Handle, Front Door Pull, LH DARK BLUE,TRIM8# Location: Driver Side Production Date: 01/1990-09/1991 Replaced by: 74814-17011-R8 (Türgriffschale links blau)
74814-17011-D3 Handle, Front Door Pull, LH RED,TRIM3# Location: Driver Side Production Date: 09/1991-01/1992 (Türgriffschale links rot)
74814-17011-R8 Handle, Front Door Pull, LH DARK BLUE,TRIM8# Location: Driver Side Production Date: 09/1991-11/1993 (Türgriffschale links blau)
74813-17010-04 Handle, Front Door Pull, RH DARK BLUE,TRIM8# Location: Passenger Side Production Date: 01/1990-09/1991 Replaced by: 74813-17011-R8 (Türgriffschale rechts blau)
74813-17011-D3 Handle, Front Door Pull, RH RED,TRIM3# Location: Passenger Side Production Date: 09/1991-01/1992 (Türgriffschale rechts rot)
74813-17011-R8 Handle, Front Door Pull, RH DARK BLUE,TRIM8# Location: Passenger Side Production Date: 09/1991-11/1993 (Türgriffschale rechts blau)
74348-30010-02 Holder, Visor RED,TRIM3# (Halterung Sonnenblende rot)
74348-30010-14 Holder, Visor DARK BLUE,TRIM8# (Halterung Sonnenblende blau)
74631-17020-02 Hook, Coat RED,TRIM3# (Kleiderhaken rot)
74631-17020-04 Hook, Coat DARK BLUE,TRIM8# (Kleiderhaken blau)
74232-17060-02 Panel, Door Armrest Base, LH RED,TRIM3# Location: Driver Side (Armlehne Tür links rot)
74231-17080-02 Panel, Door Armrest Base, RH RED,TRIM3# Location: Passenger Side (Armlehne Tür rechts rot)
74320-17210-01 Visor Assy, LH BLACK,TRIM2# Location: Driver Side (Sonnenblende links schwarz)
74320-17210-02 Visor Assy, LH RED,TRIM3# Location: Driver Side (Sonnenblende links rot)
74320-17210-04 Visor Assy, LH DARK BLUE,TRIM8# Location: Driver Side (Sonnenblende links blau)
74310-17190-01 Visor Assy, RH BLACK,TRIM2# (Sonnenblende rechts schwarz)
74310-17190-02 Visor Assy, RH RED,TRIM3# (Sonnenblende rechts rot)
74310-17190-04 Visor Assy, RH DARK BLUE,TRIM8# (Sonnenblende rechts blau)
74310-17200-01 Visor Assy, RH BLACK,TRIM2# (Sonnenblende rechts schwarz)
74310-17200-02 Visor Assy, RH RED,TRIM3# (Sonnenblende rechts rot)
74310-17200-04 Visor Assy, RH DARK BLUE,TRIM8# (Sonnenblende rechts blau)
74431-17010 Tray, Battery (Batteriefach)
44610-17210 Booster Assy, Brake (Bremskraftverstärker)
44610-17220 Booster Assy, Brake (Bremskraftverstärker)
44758-17060 Bracket, Vacuum Check Valve (Halterung Unterdruckventil Rückschlag)
44758-17070 Bracket, Vacuum Check Valve (Halterung Unterdruckventil Rückschlag)
44776-17030 Hose, Brake Booster (Schlauch Bremskraftverstärker)
44776-17040 Hose, Brake Booster (Schlauch Bremskraftverstärker)
44779-17040 Hose, Union To Connector (Schlauch Verbindung Rohr)
44764-17030 Tube, Connector To Brake Booster (Rohrleitung Verbindung Bremskraftverstärker)
44761-17011 Tube, Intake Manifold Or Vacuum Pump To Connector Production Date: 09/1991-01/1992 (Rohrleitung BKV Ansaugkrümmer)
90461-10744 CLAMP (Schelle)
47264-20040 Clevis, Master Cylinder Push Rod (Schäkel, Hauptbremszylinder)
04493-17050 Cylinder Kit, Brake Master Production Date: 11/1991-01/1992 (Hauptbremszylinder Kit)
47201-17060 Cylinder Sub-Assy, Brake Master (Hauptbremszylinder)
47201-17080 Cylinder Sub-Assy, Brake Master W(*66) (Hauptbremszylinder)
47220-16010 Reservoir Sub-Assy, Brake Master Cylinder (Behälter Bremsflüssigkeit Hauptbremszylinder)
55106-17040 Support Sub-Assy, Brake Pedal (Aufnahme Bremspedal)
44510-17010 Actuator Assy, Brake
44510-17030 Actuator Assy, Brake
44590-17020 Bracket Assy, Brake Actuator
44593-17020 Bracket, Brake Actuator, NO.3
47159-30170 Bracket, Proportioning & By-Pass Valve
44597-17020 Clamp, Brake Actuator Connector, NO.1
47371-30090 Clamp, Brake Tube, NO.1
90541-09076 Cushion(For Brake Actuator Bracket NO.4)
44546-22070 Cushion, Brake Actuator Bolt
44545-22070 Holder, Brake Actuator Bolt
44551-17020 Tube, Brake Actuator, NO.1
44552-17010 Tube, Brake Actuator, NO.2
47311-17100 Tube, Front Brake, NO.1
47311-17130 Tube, Front Brake, NO.1 W(*66)
47312-17020 Tube, Front Brake, NO.2
47312-17040 Tube, Front Brake, NO.2
47313-17080 Tube, Front Brake, NO.3 W(*66)
47321-17100 Tube, Rear Brake, NO.1
47321-17130 Tube, Rear Brake, NO.1 W(*66)
47322-17060 Tube, Rear Brake, NO.2
47322-17080 Tube, Rear Brake, NO.2
47323-17050 Tube, Rear Brake, NO.3 W(*66)
47190-14060 Valve Assy, Proportioning & By-Pass W(*66)
47190-17020 Valve Assy, Proportioning & By-Pass
47190-17040 Valve Assy, Proportioning & By-Pass
47190-17060 Valve Assy, Proportioning & By-Pass W(*66)
90412-10173 Way, NO.1(For Brake Actuator)
90949-01603 CLAMP
93315-15025 SCREW, W/WASHER
90461-06139 Standard Part
13502-88381 Camshaft, NO.2
11285-16011 Plate, Coolant System Caution
11298-74580 Plate, Emission Control Information Production Date: 01/1990-08/1991
11298-74581 Plate, Emission Control Information Production Date: 08/1991-01/1992
11298-74590 Plate, Emission Control Information CALIFORNIA SPEC Production Date: 01/1990-08/1991
11298-74591 Plate, Emission Control Information CALIFORNIA SPEC Production Date: 08/1991-01/1992
17792-74250 Plate, Engine Vacuum Hose Information Production Date: 01/1990-08/1991
17792-74251 Plate, Engine Vacuum Hose Information Production Date: 08/1991-01/1992
11294-74030 Plate, Turbocharger Caution
44391-17010 Label, Power Steering Oil Information
42661-17110 Plate, Tire Pressure Caution
42661-17130 Plate, Tire Pressure Caution
31232-32010 Clip, Release Bearing Hub TYPE 1
31232-32020 Clip, Release Bearing Hub TYPE 2
31232-32030 Clip, Release Bearing Hub TYPE 3
90105-06023 Bolt(For Clutch Release Bearing Hub Retainer)
33102-32011 Cover Sub-Assy, Manual Transmission Case Production Date: 01/1990-04/1990 Replaced by: 33102-32012
33102-32012 Cover Sub-Assy, Manual Transmission Case Production Date: 04/1990-05/1992
33124-32011 Pipe, Oil Receiver, NO.1(MTM) Production Date: 01/1990-05/1990
33124-32012 Pipe, Oil Receiver, NO.1(MTM) Production Date: 05/1990-05/1992
31404-14011 Clevis, Clutch Master Cylinder Push Rod Production Date: 01/1990-08/1991
31404-14012 Clevis, Clutch Master Cylinder Push Rod Production Date: 08/1991-01/1992
31402-17011 Reservoir Sub-Assy, Clutch Master Cylinder
90506-29011 Spring(For Clutch Pedal)
90507-14002 Spring(For Clutch Pedal)
58910-17020-02 Box Assy, Console, Rear RED,TRIM3# Location: Rear
58801-17110-01 Box, Console BLACK,TRIM2# Replaced by: 58801-17110-22
58801-17110-02 Box, Console RED,TRIM3#
58801-17110-04 Box, Console DARK BLUE,TRIM8#
58801-17120-01 Box, Console W(REAR CONSOLE BOX),BLACK,TRIM2# Replaced by: 58801-17120-22
58801-17120-02 Box, Console W(REAR CONSOLE BOX),RED,TRIM3#
58801-17120-04 Box, Console DARK BLUE,TRIM8#
58908-17010-02 Lock Sub-Assy, Console Compartment Door RED,TRIM3#
58908-17010-04 Lock Sub-Assy, Console Compartment Door DARK BLUE,TRIM8#
55716-17020 Brace, Cowl Top To Apron, LH Location: Driver Side
55715-17020 Brace, Cowl Top To Apron, RH Location: Passenger Side
55950-17040 Nozzle Assy, Defroster
55967-17020 Nozzle, Defroster, Lower Location: Lower
55700-17080 Panel Sub-Assy, Cowl
55700-17090 Panel Sub-Assy, Cowl (RADI0 ACOUSTIC FLAVOR)
55718-17020 Panel, Cowl Top Side, Inner LH Location: Inner Driver Side
55717-17020 Panel, Cowl Top Side, Inner RH Location: Inner Passenger Side
55729-17020 Reinforcement, Hood Stopper, LH Location: Driver Side
55728-17020 Reinforcement, Hood Stopper, RH Location: Passenger Side
55739-17020 Stopper, Hood, LH Location: Driver Side
55738-17020 Stopper, Hood, RH Location: Passenger Side
11701-88342-05 Bearing, Crankshaft MARK 5,NO.1,2,4,5 JOURNAL
88200-17060 Actuator Assy, Cruise Control Replaced by: 88200-17070
88291-17030 Bracket, Cruise Control(Auto Drive), NO.1
88292-17030 Bracket, Cruise Control(Auto Drive), NO.2
88240-17140 Computer Assy, Cruise Control
84630-17030 Switch Assy, Cruise Control Main
11401-79455 Block Sub-Assy, Cylinder Production Date: 01/1990-08/1991
12123-88360 Plate, Oil Pan Baffle NO.3
11123-88320 Bush, Exhaust Valve Guide O/S 0.05
11123-88320 Bush, Intake Valve Guide O/S 0.05
11201-88383 Cover Sub-Assy, Cylinder Head Production Date: 01/1990-12/1991 Replaced by: 11201-88385
11201-88385 Cover Sub-Assy, Cylinder Head Production Date: 12/1991-06/1995
11101-88384 Head Sub-Assy, Cylinder Production Date: 01/1990-01/1991 Replaced by: 11101-88391
11101-88386 Head Sub-Assy, Cylinder Production Date: 01/1991-07/1991 Replaced by: 11101-88391
11101-88389 Head Sub-Assy, Cylinder Production Date: 07/1991-08/1991 Replaced by: 11101-88391
11101-88391 Head Sub-Assy, Cylinder Production Date: 08/1991-06/1995
42621-17010 Cap, Wheel
42611-17090-01 Wheel, Disc (For Front) 14X6JJ,TYPE C,BLACK,043 ,202 ,3J6 ,567 ,742 ,8H3
42611-17110 Wheel, Disc (For Front) 14X6JJ,ALUMINUM,TYPE D
42611-17150-01 Wheel, Disc (For Rear) 14X7JJ,TYPE C,BLACK,043 ,202 ,3J6 ,567 ,742 ,8H3
42611-17140 Wheel, Disc (For Spare) 15X4T,TYPE A
19100-88363 Distributor Assy
85720-17030 Motor Assy, Power Window Regulator, Front LH Location: Front Driver Side
89668-17050 Bracket, Engine Control Computer, NO.2
28519-74060 Bracket, Solenoid Resistor
89661-17240 Computer, Engine Control CALIFORNIA SPEC Production Date: 01/1990-09/1990 Replaced by: 89661-17241-84
89661-17241 Computer, Engine Control CALIFORNIA SPEC Production Date: 09/1990-01/1992
89661-17260 Computer, Engine Control Replaced by: 89661-17260-84
89661-17330 Computer, Engine Control Production Date: 01/1990-03/1990 Replaced by: 89661-17332-84
89661-17331 Computer, Engine Control Production Date: 03/1990-01/1991 Replaced by: 89661-17332-84
89661-17332 Computer, Engine Control Production Date: 01/1991-01/1992 Replaced by: 89661-17332-84
28380-74040 Relay Assy, Fuel Pump
28515-74080 Resistor, Solenoid
89420-17040 Sensor Assy, Vacuum (For E.F.I.)
75442-17060-02 Plate, Luggage Compartment Door Name, NO.2 TURBO,SUPER RED 3,3J6 Replaced by: 75442-17060-D0
75442-17060-03 Plate, Luggage Compartment Door Name, NO.2 TURBO,BLUISH GRAY ARGENTUM,187 Replaced by: 75442-17060-17
75442-17060-04 Plate, Luggage Compartment Door Name, NO.2 TURBO,BLUE M,8H3
75442-17060-07 Plate, Luggage Compartment Door Name, NO.2 TURBO,D. TURQUQISE M,742 Replaced by: 75442-17060-G0
75442-17060-08 Plate, Luggage Compartment Door Name, NO.2 TURBO,SUPER WHITE 3,043 Replaced by: 75442-17060-A0
75471-17050-02 Plate, Rear Name MR2,W(PAINTED),SUPER RED 2,3J6
75471-17050-08 Plate, Rear Name MR2,W(PAINTED),SUPER WHITE 3,043
75471-17050-09 Plate, Rear Name MR2,W(PAINTED),SUPER BRIGHT YELLOW,567
75441-17080-03 Plate, Rear Name, No.1 TOYOTA,BLUISH GRAY ARGENTUM,187 Replaced by: 75441-17080-17
75441-17080-04 Plate, Rear Name, No.1 TOYOTA,BLUE M,8H3
75441-17080-07 Plate, Rear Name, No.1 TOYOTA,D. TURQUQISE M,742 Replaced by: 75441-17080-G0
75441-17080-08 Plate, Rear Name, No.1 TOYOTA,SUPER WHITE 3,043 Replaced by: 75441-17080-A0
75441-17080-09 Plate, Rear Name, No.1 TOYOTA,SUPER BRIGHT YELL0W,567 Replaced by: 75441-17080-F0
69365-17020-02 Bezel, Engine Hood Lock Control RED,TRIM3#
53605-17010 Brace Sub-Assy, Rear Suspension, Upper Location: Upper
68810-17060 Hinge Assy, Engine Hood, RH Location: Passenger Side
69350-17040 Lock Assy, Engine Hood
69350-17070 Lock Assy, Engine Hood W(ANTI-THEFT DEVICE)
90508-10034 Spring, Torsion(For Engine Hood Lock Control Lever)
82711-12200 CLAMP, WIRING HARNES
15700-88380 Cooler Assy, Oil
15690-88380 Valve Assy, Oil Cooler Relief
15132-88380 Spring, Oil Pump Relief Valve
25695-88381 Hose(For EGR Vacuum Modulator)
25620-74220 Valve Assy, EGR
64273-17010 Pad, Room Partition, NO.1
64274-17010 Pad, Room Partition, NO.2
58101-17908 Pan Sub-Assy, Front Floor
64206-17090 Panel Sub-Assy, Room Partition
57108-17040 Bracket Sub-Assy, Strut Bar, LH Location: Driver Side
57107-17040 Bracket Sub-Assy, Strut Bar, RH Location: Passenger Side
57103-17010 Crossmember Sub-Assy, Floor, NO.3
57408-17020 Member Sub-Assy, Front Floor Cross
57102-17110 Member Sub-Assy, Front Side, LH Location: Driver Side
57101-17070 Member Sub-Assy, Front Side, RH Location: Passenger Side
57602-17090 Member Sub-Assy, Rear Floor Side, LH Location: Driver Side
57604-17030 Member Sub-Assy, Rear Floor Side, Rear LH Location: Rear Driver Side
57106-17901 Plate Sub-Assy, Front Side Member, LH Location: Driver Side
57105-17901 Plate Sub-Assy, Front Side Member, RH Location: Passenger Side
57192-17040 Plate, Front Side Member, Outer Rear LH Location: Outer Rear Driver Side
57191-17040 Plate, Front Side Member, Outer Rear RH Location: Outer Rear Passenger Side
57632-17020 Reinforcement, Rear Floor Side Member, Front LH Location: Front Driver Side
57631-17020 Reinforcement, Rear Floor Side Member, Front RH Location: Front Passenger Side
90119-08853 BOLT, W/WASHER
48069-17020 Arm Sub-Assy, Front Suspension, Lower NO.1 LH Location: Driver Side
43212-17030 Knuckle, Steering, LH Location: Driver Side
43212-17040 Knuckle, Steering, LH W(*66) Location: Driver Side
43212-17060 Knuckle, Steering, LH W(*66 & POWER STEERING) Location: Driver Side
43211-17030 Knuckle, Steering, RH Location: Passenger Side
43211-17040 Knuckle, Steering, RH W(*66) Location: Passenger Side
43211-17060 Knuckle, Steering, RH W(*66 & POWER STEERING) Location: Passenger Side
52712-17040-02 Moulding, Front Bumper Side, RH SUPER RED 3,3J6 Location: Passenger Side
52712-17040-03 Moulding, Front Bumper Side, RH LIGHT SILVER M.,043 Location: Passenger Side
52712-17040-04 Moulding, Front Bumper Side, RH BLUE,M,8H3 Location: Passenger Side
52712-17040-07 Moulding, Front Bumper Side, RH DARK TURQUOISE MICA,742 Location: Passenger Side Replaced by: 52712-17040-C0
52712-17040-13 Moulding, Front Bumper Side, RH DARK GRAY M,187 ,202 ,567 Location: Passenger Side
52713-17020 Plug, Front Bumper Moulding
52713-17040-02 Plug, Front Bumper Moulding SUPER RED 3,3J6
52713-17040-03 Plug, Front Bumper Moulding LIGHT SILVER M.,043
52713-17040-04 Plug, Front Bumper Moulding BLUE,M,8H3
52713-17040-07 Plug, Front Bumper Moulding DARK TURQUOISE MICA,742 Replaced by: 52713-17040-C0
76863-17020 Retainer, Front Spoiler, Lower NO.2
47750-17080 Cylinder Assy, Disc Brake, LH Location: Driver Side
47750-17090 Cylinder Assy, Disc Brake, LH Location: Driver Side
47730-17090 Cylinder Assy, Front Disc Brake, RH Location: Passenger Side
04947-32090 Fitting Kit, Disc Brake, Front Location: Front
47721-17030 Mounting, Front Disc Brake Cylinder, LH Location: Driver Side
47722-17010 Mounting, Front Disc Brake Cylinder, LH Location: Driver Side
47721-17030 Mounting, Front Disc Brake Cylinder, RH Location: Passenger Side
47721-17040 Mounting, Front Disc Brake Cylinder, RH Location: Passenger Side
47716-17020 Plate, Pad Support, NO.1(For Front Disc Brake)
47716-17020 Plate, Pad Support, NO.2(For Front Disc Brake)
04945-17050 Shim Kit, Anti Squeal, Front Location: Front
47745-17020 Shim, Anti-Squeal, NO.1(For Front Disc Brake)
47745-17030 Shim, Anti-Squeal, NO.1(For Front Disc Brake)
47745-17030 Shim, Anti-Squeal, NO.2(For Front Disc Brake)
47742-17010 Shim, Anti-Squeal, NO.3(For Front Disc Brake)
47742-17020 Shim, Anti-Squeal, NO.3(For Front Disc Brake)
47742-17020 Shim, Anti-Squeal, NO.4(For Front Disc Brake)
69707-17010 Bellcrank Sub-Assy, Door Lock Control, Lower Location: Lower
69220-17030-02 Handle Assy, Front Door Outside, LH SUPER RED 3,3J6 Location: Driver Side
69220-17030-03 Handle Assy, Front Door Outside, LH BLUEISH GRY ARGENTUM,187 Location: Driver Side Replaced by: 69220-17030-17
69220-17030-04 Handle Assy, Front Door Outside, LH BLUE,M,8H3 Location: Driver Side
69220-17030-07 Handle Assy, Front Door Outside, LH DARK TURQUOISE MICA,742 Location: Driver Side
69220-17030-08 Handle Assy, Front Door Outside, LH SUPER WHITE 3,043 Location: Driver Side
69220-17030-09 Handle Assy, Front Door Outside, LH SUPER BRIGHT YELLOW,567 Location: Driver Side
69220-17040-03 Handle Assy, Front Door Outside, LH W(POWER WINDOW),BLUEISH GRY ARGENTUM,187 Location: Driver Side Replaced by: 69220-17030-17
69220-17040-08 Handle Assy, Front Door Outside, LH W(POWER WINDOW),SUPER WHITE 3,043 Location: Driver Side Replaced by: 69220-17030-08
69210-17040-01 Handle Assy, Front Door, Outside RH BLACK,202 Location: Outside Passenger Side Replaced by: 69210-17040-22
69210-17040-02 Handle Assy, Front Door, Outside RH SUPER RED 3,3J6 Location: Outside Passenger Side
69210-17040-03 Handle Assy, Front Door, Outside RH BLUEISH GRY ARGENTUM,187 Location: Outside Passenger Side Replaced by: 69210-17040-17
69210-17040-04 Handle Assy, Front Door, Outside RH BLUE,M,8H3 Location: Outside Passenger Side
69210-17040-07 Handle Assy, Front Door, Outside RH DARK TURQUOISE MICA,742 Location: Outside Passenger Side
69210-17040-08 Handle Assy, Front Door, Outside RH SUPER WHITE 3,043 Location: Outside Passenger Side
69210-17040-09 Handle Assy, Front Door, Outside RH SUPER BRIGHT YELLOW,567 Location: Outside Passenger Side
69206-17030-01 Handle Sub-Assy, Front Door Inside, LH BLACK,TRIM2# Location: Driver Side
69206-17030-02 Handle Sub-Assy, Front Door Inside, LH RED,TRIM3# Location: Driver Side
69206-17030-04 Handle Sub-Assy, Front Door Inside, LH D,BLUE,TRIM8# Location: Driver Side Replaced by: 69206-17030-01
69205-17030-01 Handle Sub-Assy, Front Door Inside, RH BLACK,TRIM2# Location: Passenger Side
69205-17030-02 Handle Sub-Assy, Front Door Inside, RH RED,TRIM3# Location: Passenger Side
69205-17030-04 Handle Sub-Assy, Front Door Inside, RH D,BLUE,TRIM8# Location: Passenger Side Replaced by: 69205-17030-01
69731-17010 Link, Front Door Inside Locking, NO.1 RH Location: Passenger Side
69712-17020 Link, Front Door Lock Remote Control, LH Location: Driver Side
69711-17030 Link, Front Door Lock Remote Control, RH Location: Passenger Side
69040-17091 Lock Assy, Front Door, LH W(ANTI-THEFT DEVICE) Location: Driver Side Replaced by: 69040-17092
69320-17101 Lock Assy, Front Door, LH Location: Driver Side
69030-17061 Lock Assy, Front Door, RH W(POWER WINDOW) Location: Passenger Side
69030-17091 Lock Assy, Front Door, RH W(ANTI-THEFT DEVICE) Location: Passenger Side
69310-17101 Lock Assy, Front Door, RH Location: Passenger Side
69410-17010 Plate Assy, Front Door Lock Striker
67620-17320-01 Board Sub-Assy, Front Door Trim, LH POWER PACKAGE,BLACK,TRIM2# Location: Driver Side
67620-17320-02 Board Sub-Assy, Front Door Trim, LH POWER PACKAGE,RED,TRIM3# Location: Driver Side
67620-17320-04 Board Sub-Assy, Front Door Trim, LH POWER PACKAGE,DARK BLUE,TRIM8# Location: Driver Side
67620-17330-01 Board Sub-Assy, Front Door Trim, LH POWER & LEATHER PACKAGE & W(POWER WINDOW),BLACK,TRIM2# Location: Driver Side
67620-17340-01 Board Sub-Assy, Front Door Trim, LH BLACK,TRIM2# Location: Driver Side
67620-17340-02 Board Sub-Assy, Front Door Trim, LH RED,TRIM3# Location: Driver Side
67620-17340-04 Board Sub-Assy, Front Door Trim, LH DARK BLUE,TRIM8# Location: Driver Side
67620-17360-01 Board Sub-Assy, Front Door Trim, LH LUXURY PACKAGE,BLACK,TRIM2# Location: Driver Side
67620-17360-02 Board Sub-Assy, Front Door Trim, LH RED,TRIM3# Location: Driver Side
67620-17360-04 Board Sub-Assy, Front Door Trim, LH LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Driver Side
67610-17360-01 Board Sub-Assy, Front Door Trim, RH POWER PACKAGE,BLACK,TRIM2# Location: Passenger Side
67610-17360-02 Board Sub-Assy, Front Door Trim, RH POWER PACKAGE,RED,TRIM3# Location: Passenger Side
67610-17360-04 Board Sub-Assy, Front Door Trim, RH POWER PACKAGE,DARK BLUE,TRIM8# Location: Passenger Side
67610-17370-01 Board Sub-Assy, Front Door Trim, RH POWER & LEATHER PACKAGE & W(POWER WINDOW),BLACK,TRIM2# Location: Passenger Side
67610-17390-01 Board Sub-Assy, Front Door Trim, RH BLACK,TRIM2# Location: Passenger Side
67610-17390-02 Board Sub-Assy, Front Door Trim, RH RED,TRIM3# Location: Passenger Side
67610-17390-04 Board Sub-Assy, Front Door Trim, RH DARK BLUE,TRIM8# Location: Passenger Side
90339-10002-12 Cap(For Front Door Trim Board) RED,TRIM3#
67492-17040 Garnish, Front Door Lower Frame Bracket, LH Location: Driver Side
67491-17040 Garnish, Front Door Lower Frame Bracket, RH Location: Passenger Side
67404-17030 Guide Sub-Assy, Front Door Window, Rear LH Location: Rear Driver Side
67403-17030 Guide Sub-Assy, Front Door Window, Rear RH Location: Rear Passenger Side
67112-17030 Panel, Front Door, Outer LH Location: Outer Driver Side
67111-17030 Panel, Front Door, Outer RH Location: Outer Passenger Side
67778-17040-01 Pocket, Front Door Trim, LH BLACK,TRIM2# Location: Driver Side Replaced by: 67778-17040-C1
67778-17040-02 Pocket, Front Door Trim, LH RED,TRIM3# Location: Driver Side
67778-17040-04 Pocket, Front Door Trim, LH DARK BLUE,TRIM8# Location: Driver Side
67780-17030-01 Pocket, Front Door Trim, LH W(POWER WINDOW),BLACK,TRIM2# Location: Driver Side Replaced by: 67780-17030-C0
67780-17030-02 Pocket, Front Door Trim, LH W(POWER WINDOW),RED,TRIM3# Location: Driver Side
67780-17030-04 Pocket, Front Door Trim, LH W(POWER WINDOW),DARK BLUE,TRIM8# Location: Driver Side
67770-17030-01 Pocket, Front Door Trim, RH W(POWER WINDOW),BLACK,TRIM2# Location: Passenger Side
67770-17030-02 Pocket, Front Door Trim, RH W(POWER WINDOW),RED,TRIM3# Location: Passenger Side
67770-17030-04 Pocket, Front Door Trim, RH W(POWER WINDOW),DARK BLUE,TRIM8# Location: Passenger Side
67777-17040-02 Pocket, Front Door Trim, RH RED,TRIM3# Location: Passenger Side
67777-17040-04 Pocket, Front Door Trim, RH DARK BLUE,TRIM8# Location: Passenger Side
68127-17021 Plate, Front Door Glass, Rear RH Location: Rear Passenger Side
69820-17040 Regulator Sub-Assy, Front Door Window, LH Location: Driver Side
69810-17040 Regulator Sub-Assy, Front Door Window, RH Location: Passenger Side
67211-17030 Stop, Front Door Window, Upper MARK 2 Location: Upper
67233-20040 Support, Rear Door Trim MARK 2 Production Date: 01/1990-04/1990 Replaced by: 67233-20041
67233-20041 Support, Rear Door Trim MARK 2 Production Date: 04/1990-11/1993
90119-08012 BOLT, W/WASHER Replaced by: 91651-40812
53701-17050 Apron Sub-Assy, Front Fender, RH Location: Passenger Side
55226-17020 Cover, Dash Panel Front Trim
53788-17020 Gusset, Front Fender Apron, Lower LH Location: Lower Driver Side Production Date: 01/1990-12/1991
53787-17020 Gusset, Front Fender Apron, Lower RH Location: Lower Passenger Side Production Date: 01/1990-12/1991
55210-17040 Insulator Assy, Dash Panel
57302-17030 Member Sub-Assy, Front Luggage Cross
57301-17060 Member Sub-Assy, Steering Gear Box Support Production Date: 01/1990-12/1991 Replaced by: 48824-17030
57301-17070 Member Sub-Assy, Steering Gear Box Support W(ELECTRICAL TYPE POWER STEERING) Replaced by: 48824-17030
57308-17060 Pan Sub-Assy, Front Luggage W(ELECTRICAL TYPE POWER STEERING)
55101-17080 Panel Sub-Assy, Dash
55102-17050 Panel Sub-Assy, Dash, Lower Location: Lower
57307-17060 Panel Sub-Assy, Front Luggage End
53211-17030 Support, Radiator, RH Location: Passenger Side
72760-17020 Adjuster Assy, Lumbar Support, LH Location: Driver Side
72020-17090 Adjuster Sub-Assy, Front Seat, LH LUXURY PACKAGE Location: Driver Side
72020-17100 Adjuster Sub-Assy, Front Seat, LH Location: Driver Side
72010-17110 Adjuster Sub-Assy, Front Seat, RH Location: Passenger Side
71074-17240-01 Cover, Front Seat Back, LH(For Separate Type) BLACK,TRIM2# Location: Driver Side
71074-17240-02 Cover, Front Seat Back, LH(For Separate Type) RED,TRIM3# Location: Driver Side
71074-17240-04 Cover, Front Seat Back, LH(For Separate Type) DARK BLUE,TRIM8# Location: Driver Side
71074-17260-01 Cover, Front Seat Back, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Driver Side
71074-17260-02 Cover, Front Seat Back, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Driver Side
71074-17260-04 Cover, Front Seat Back, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Driver Side
71074-17280-01 Cover, Front Seat Back, LH(For Separate Type) POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Driver Side Replaced by: 71074-17282-C1
71073-17240-01 Cover, Front Seat Back, RH(For Separate Type) BLACK,TRIM2# Location: Passenger Side
71073-17240-02 Cover, Front Seat Back, RH(For Separate Type) RED,TRIM3# Location: Passenger Side
71073-17240-04 Cover, Front Seat Back, RH(For Separate Type) DARK BLUE,TRIM8# Location: Passenger Side
71073-17260-01 Cover, Front Seat Back, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Passenger Side
71073-17260-02 Cover, Front Seat Back, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Passenger Side
71073-17260-04 Cover, Front Seat Back, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Passenger Side
71073-17280-01 Cover, Front Seat Back, RH(For Separate Type) POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Passenger Side Replaced by: 71073-17282-C1
71072-17180-01 Cover, Front Seat Cushion, LH(For Separate Type) BLACK,TRIM2# Location: Driver Side
71072-17180-02 Cover, Front Seat Cushion, LH(For Separate Type) RED,TRIM3# Location: Driver Side
71072-17180-04 Cover, Front Seat Cushion, LH(For Separate Type) DARK BLUE,TRIM8# Location: Driver Side
71072-17200-01 Cover, Front Seat Cushion, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Driver Side
71072-17200-02 Cover, Front Seat Cushion, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Driver Side
71072-17200-04 Cover, Front Seat Cushion, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Driver Side
71072-17220-01 Cover, Front Seat Cushion, LH(For Separate Type) POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Driver Side
71071-17180-01 Cover, Front Seat Cushion, RH(For Separate Type) BLACK,TRIM2# Location: Passenger Side
71071-17180-02 Cover, Front Seat Cushion, RH(For Separate Type) RED,TRIM3# Location: Passenger Side
71071-17180-04 Cover, Front Seat Cushion, RH(For Separate Type) DARK BLUE,TRIM8# Location: Passenger Side
71071-17200-01 Cover, Front Seat Cushion, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Passenger Side
71071-17200-02 Cover, Front Seat Cushion, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Passenger Side
71071-17200-04 Cover, Front Seat Cushion, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Passenger Side
71071-17220-01 Cover, Front Seat Cushion, RH(For Separate Type) POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Passenger Side
72128-17010-02 Cover, Seat Track Bracket, Inner Front LH RED,TRIM3# Location: Inner Front Driver Side
72127-17010-02 Cover, Seat Track Bracket, Inner Front RH RED,TRIM3# Location: Inner Front Passenger Side
72127-17010-04 Cover, Seat Track Bracket, Inner Front RH DARK BLUE,TRIM8# Location: Inner Front Passenger Side
72123-17010-02 Cover, Seat Track Bracket, Outer Front RED,TRIM3#
71910-17110-01 Headrest Assy, Front Seat BLACK,TRIM2#
71910-17110-02 Headrest Assy, Front Seat LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3#
71910-17110-04 Headrest Assy, Front Seat DARK BLUE,TRIM8#
71910-17140-01 Headrest Assy, Front Seat BLACK,TRIM2#
71910-17140-02 Headrest Assy, Front Seat RED,TRIM3#
71910-17140-04 Headrest Assy, Front Seat DARK BLUE,TRIM8#
71506-17070 Pad Sub-Assy, Front Seat Back W/Frame, LH Location: Driver Side
71506-17080 Pad Sub-Assy, Front Seat Back W/Frame, LH LUXURY PACKAGE Location: Driver Side
71505-17070 Pad Sub-Assy, Front Seat Back W/Frame, RH Location: Passenger Side
71553-17020 Pad, Front Seat Back, B
71553-17020 Pad, Front Seat Back, B LUXURY PACKAGE Location: Passenger Side
71553-17010 Pad, Front Seat Back, C LUXURY PACKAGE OR LUXURY & LEATHER PACKAGE
71553-17020 Pad, Front Seat Back, C
71512-17100 Pad, Front Seat Cushion, LH (For Separate Type) Location: Driver Side
71511-17090 Pad, Front Seat Cushion, RH(For Separate Type) Location: Passenger Side
71200-17410-01 Seat Assy, Front LH ***,BLACK,TRIM2# Location: Front Driver Side
71200-17410-02 Seat Assy, Front LH ***,RED,TRIM3# Location: Front Driver Side
71200-17410-04 Seat Assy, Front LH ***,DARK BLUE,TRIM8# Location: Front Driver Side
71200-17450-01 Seat Assy, Front LH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Front Driver Side
71200-17450-02 Seat Assy, Front LH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Front Driver Side
71200-17450-04 Seat Assy, Front LH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Front Driver Side
71200-17480-01 Seat Assy, Front LH ***,POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Front Driver Side
71100-17410-01 Seat Assy, Front RH ***,BLACK,TRIM2# Location: Front Passenger Side
71100-17410-02 Seat Assy, Front RH ***,RED,TRIM3# Location: Front Passenger Side
71100-17410-04 Seat Assy, Front RH ***,DARK BLUE,TRIM8# Location: Front Passenger Side
71100-17450-01 Seat Assy, Front RH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Front Passenger Side
71100-17450-02 Seat Assy, Front RH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Front Passenger Side
71100-17450-04 Seat Assy, Front RH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Front Passenger Side
71100-17480-01 Seat Assy, Front RH ***,POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Front Passenger Side
71812-17040-02 Shield, Front Seat Cushion, LH RED,TRIM3# Location: Driver Side
71812-17040-04 Shield, Front Seat Cushion, LH DARK BLUE,TRIM8# Location: Driver Side
71811-17040-02 Shield, Front Seat Cushion, RH RED,TRIM3# Location: Passenger Side
71811-17040-04 Shield, Front Seat Cushion, RH DARK BLUE,TRIM8# Location: Passenger Side
71930-17020-02 Support, Front Seat Headrest W(LOCK),RED,TRIM3#
71930-17020-04 Support, Front Seat Headrest W(LOCK),DARK BLUE,TRIM8#
71931-17010-02 Support, Front Seat Headrest W/O(LOCK),RED,TRIM3#
71931-17010-04 Support, Front Seat Headrest W/O(LOCK),DARK BLUE,TRIM8#
72140-17070 Track Assy, Front Seat, Inner LH Location: Inner Driver Side
72130-17100 Track Assy, Front Seat, Inner RH Location: Inner Passenger Side
48811-17050 Bar, Stabilizer, Front Location: Front
48811-17060 Bar, Stabilizer, Front W(POWER STEERING) Location: Front Production Date: 01/1990-03/1990
48811-17070 Bar, Stabilizer, Front W(POWER STEERING) Location: Front Production Date: 03/1990-01/1992
48811-17080 Bar, Stabilizer, Front W(POWER STEERING) Location: Front
48811-17090 Bar, Stabilizer, Front W(POWER STEERING) Location: Front
48824-17030 Bracket, Stabilizer, Front Location: Front Production Date: 10/1991-01/1992
48815-17040 Bush, Front Stabilizer Bar, NO.1 Production Date: 01/1990-03/1990
48815-17080 Bush, Front Stabilizer Bar, NO.1 W(POWER STEERING)
48131-17280 Spring, Front Coil, LH Location: Driver Side Production Date: 03/1990-01/1992
48131-17310 Spring, Front Coil, LH Location: Driver Side
48131-17280 Spring, Front Coil, RH Location: Passenger Side Production Date: 03/1990-01/1992
48131-17310 Spring, Front Coil, RH Location: Passenger Side
48815-17050 Standard Part
45524-10030 Cap, Steering Rack Guide Spring W(POWER STEERING)
44218-12020 Gasket, Valve Housing
44250-17020 Gear Assy, Power Steering(For Rack & Pinion)
45510-17040 Gear Assy, Steering
45516-17020 Grommet, Steering Rack Housing, NO.1
45501-17040 Housing Sub-Assy, Steering Rack
44022-17020 Housing, Control Valve
45196-50010 Label, Steering Shaft Installation Caution
90179-36001 Nut(For Steering Rack Guide Spring Cap)
45541-17030 Pinion, Steering
44204-17020 Rack Sub-Assy, Power Steering
45521-17040 Rack, Steering
44210-17020 Valve Assy, Power Steering Control
44201-17020 Valve Sub-Assy, Power Steering Control
22210-74490 Body Assy, Throttle
23264-74040 Bracket, Fuel Filter
23261-88380 Cover, Injector
23260-79175 Injector Assy, Cold Start Fuel
23814-88382 Pipe Sub-Assy, Fuel Delivery
23801-88381 Pipe Sub-Assy, Fuel, NO.1
23902-88380 Tube Sub-Assy, Fuel
23903-88380 Tube Sub-Assy, Fuel, NO.3
91651-G0832 BOLT, W/WASHER
90461-08680 CLAMP
90079-11038 SCREW, W/WASHER
91611-G0812 Standard Part
77601-17020 Band Sub-Assy, Fuel Tank, NO.1
77035-17060 Cable Sub-Assy, Fuel Lid Lock Control
77740-17020 Canister Assy, Charcoal
77653-17010 Cushion, Fuel Tank, NO.3
77654-17010 Cushion, Fuel Tank, NO.4
77655-17010 Cushion, Fuel Tank, NO.5
77262-17010 Gasket, Fuel Filler Pipe
23271-74250 Hose, Fuel, NO.1(For Return Tube, NO.1)
77350-17020 Lid Assy, Fuel Filler Opening
77264-17030 Tube, Fuel, NO.1(For Charcoal Canister)
90949-01499 CLAMP
33201-32010 Arm, Reverse Shift
33290-32012 Ball Assy, Lock, NO.1
33290-32020 Ball Assy, Lock, NO.2 Production Date: 01/1990-07/1990 Replaced by: 33290-32021
33290-32021 Ball Assy, Lock, NO.2 Production Date: 07/1990-08/1992
90109-18002 Bolt (For Shift Inter Lock Plate)
33240-32020 Bracket Assy, Reverse Shift Arm
33228-32010 Bracket, Reverse Shift Arm
33506-17020 Cover, Control Shaft
33506-17030 Cover, Control Shaft Replaced by: 33506-17070
33212-20060 Fork, Gear Shift, NO.1
33211-32010 Fork, Reverse Shift Production Date: 01/1990-05/1990
33211-32020 Fork, Reverse Shift Production Date: 05/1990-09/1991 Replaced by: 33270-32010
33270-32010 Fork, Reverse Shift Production Date: 09/1991-01/1992
33232-20010 Head, Gear Shift, NO.1
33256-20010 Lever, Select Inner
33251-32031 Lever, Shift, Inner NO.1
33252-32030 Lever, Shift, Inner NO.2
33208-32021 Pin Sub-Assy, Reverse Restrict Production Date: 01/1990-11/1990
33208-32022 Pin Sub-Assy, Reverse Restrict Production Date: 11/1990-08/1992
33223-32010 Pivot, Shift Arm
33206-32022 Plate Sub-Assy, Shift Inter Lock Production Date: 01/1990-11/1990
33206-32023 Plate Sub-Assy, Shift Inter Lock Production Date: 11/1990-08/1992
33266-20010 Plate, Shift Inter Lock
33266-32022 Plate, Shift Inter Lock
33276-20010 Seat, Select Spring, NO.1
33205-20010 Shaft Sub-Assy, Gear Shift Fork, NO.1
33242-32011 Shaft, Gear Shift Fork, NO.1 Production Date: 01/1990-05/1990
33242-32020 Shaft, Gear Shift Fork, NO.1 Production Date: 05/1990-01/1992
33244-20040 Shaft, Gear Shift Fork, NO.3
33261-17030 Shaft, Shift & Select Lever
33261-17040 Shaft, Shift & Select Lever
90501-10048 Spring, Compression(For Reverse Shift Arm Roller)
90501-14092 Spring, Compression, NO.1 (For Select Return) Replaced by: 90501-14129
90501-16102 Spring, Compression, NO.1 (For Select Return)
90501-14135 Spring, Compression, NO.2 (For Select Return)
90501-18068 Spring, Compression, NO.2 (For Select Return)
88444-17020 Bracket, Idle Pulley
88376-17020 Cap, Blind SUCTION
88321-14011 Head, Cooler Compressor Cylinder Location: Front Production Date: 01/1990-06/1990
88321-30300 Head, Cooler Compressor Cylinder Location: Front Production Date: 06/1990-06/1995
88322-32030 Head, Cooler Compressor Cylinder Location: Rear
88403-12030 Hub Sub-Assy, Magnet Clutch
88356-12010 Label, Compressor Caution
88341-14010 Plate Sub-Assy, Valve Location: Front
88342-14010 Plate Sub-Assy, Valve Location: Rear
88344-14011 Reed, Discharge Valve
88343-14011 Reed, Suction Valve
88412-17010 Rotor Sub-Assy, Magnet Clutch
88411-17060 Stator Sub-Assy, Magnet Clutch
88371-17100 Valve, Suction
90099-04255 BOLT, SERVICE VALVE
90099-04968 BOLT, THROUGH
88688-17320 BRACKET, COOLER
90099-13024 KEY Replaced by: 90099-13012
90099-05253 NUT
90099-08058 PIN, STRAIGHT Replaced by: 88328-01010
90099-07127 RING, SNAP (FOR MAGNET CLUTCH)
84998-10310 Cap, Air Conditioner Control Bulb 14V 0.84W
55900-17100 Control Assy, Air Conditioner Production Date: 01/1990-08/1990 Replaced by: 55900-17120
55900-17110 Control Assy, Air Conditioner W(AIR CONDITIONER) Production Date: 01/1990-08/1990 Replaced by: 55900-17130
55900-17120 Control Assy, Air Conditioner Production Date: 08/1990-11/1993
55900-17130 Control Assy, Air Conditioner W(AIR CONDITIONER) Production Date: 08/1990-11/1993
55086-17020 Duct Sub-Assy, Heater To Register, NO.3
87201-17040 Duct, Air, NO.1
55843-17040 Duct, Heater To Register, NO.1
55846-17020 Duct, Heater To Register, NO.4
88578-17080 PACKING, COOLER, NO.
88578-17090 PACKING, COOLER, NO.
88473-17030 Holder, Receiver
88715-17112 Pipe, Cooler Refrigerant Discharge, A Production Date: 11/1991-11/1993
88715-17120 Pipe, Cooler Refrigerant Discharge, B Production Date: 01/1990-03/1990 Replaced by: 88705-17040
88716-17100 Pipe, Cooler Refrigerant Liquid, B
88717-17090 Pipe, Cooler Refrigerant Suction, A
88705-17040 Tube Sub-Assy, Discharge Production Date: 01/1990-03/1990
90099-04431 BOLT, WASHER HEAD
88688-17280 BRACKET, COOLER
88718-17130 CLAMP, PIPING
88718-17140 CLAMP, PIPING
88718-17150 CLAMP, PIPING
88718-17160 CLAMP, PIPING
88718-17170 CLAMP, PIPING
88718-17190 CLAMP, PIPING
88718-17210 CLAMP, PIPING
88718-17230 CLAMP, PIPING
88718-17240 CLAMP, PIPING
88718-17260 CLAMP, PIPING
90480-27004 GROMMET
88714-17090 INSULATOR, PIPING
88714-17110 INSULATOR, PIPING
88714-17011 Standard Part
88714-17100 Standard Part
88716-17170 Standard Part
88650-17120 Amplifier Assy, Cooler Stabilizer
88605-17270 Harness Sub-Assy, Cooler Wiring, NO.1
88648-17030 Harness Sub-Assy, Cooler Wiring, NO.2
88539-17040 Hose, Cooler Unit Drain, NO.1
88510-17140 Unit Assy, Cooler
88688-17340 BRACKET, COOLER
88688-17370 BRACKET, COOLER
88569-17150 CLAMP, COOLER, NO.1
88578-17070 PACKING, COOLER, NO.
88714-10020 PIPE, INSULATOR
88688-17250 Standard Part
87130-17080 Blower Assy, Heater, Front Location: Front
87211-17020 Duct, Air
87150-17240 Radiator Assy, Heater Replaced by: 87150-17241
87106-17120 Servo Sub-Assy, Damper(For Blower)
90099-00181 SCREW
89543-17010 ABS-Sensor vorne links
48815-17100 Bushing Stabilizer
89629-17020 BRACKET, IGNITER ASSY
90949-01603 CLAMP
90461-08680 CLAMP
90949-01499 CLAMP
90099-05253 NUT
90480-27004 GROMMET
90099-00181 SCREW
No guarantee that you aren't able to find an example of these parts somewhere...but they are officially classed as disco-parts (discontiniued)
lmao almost the whole car
If you see an MR2 with a raised engine cover, the bottom line is it's probably faster than your car.
And that's only what i managed to grab hold of before my access was revoked
Oh wow, that is really useful.
Thanks.
Thanks.
Blue Lexus RCF
