I know this pipe use to feed into the rubber S bend
This pipe on the turbo itself, cant tell where it goes easily.
jimGTS wrote:Those 2 are not related.
The turbo pipe needs to fit into the actuator(rerouting required if your running a boost controller)
The other pipe feeds to the idle control valve.Fit a breather there.
Standard the hose goes to the intake'before' the turbo.
jimGTS wrote:you can put the new breather further back on that line instead if you dont want next to each other.
yeh boost controller can fit between turbo nipple and the empty nipple of the actuator also shown in the pic if you zoom in
