I'm experiencing a lack of boost after changing gear on my Rev1 turbo engine, which I thought was due to the wastegate sticking open but now not so sure.
I first noticed this last year with the original CT26 turbo when I was at Snetterton.
As I lost a few impeller blades I replaced this with a CT20B and took some time to file down the edges of the wastegate flap and the inside of my Ebay downpipe until i was comfortable that it wasn't catching, this was without the exhaust gasket, so including the metal layered gasket when fitting there should have been even more clearance.
Unfortunately once I was back on the road the same thing was happening.
Previously with the CT26 I just had stock boost control, now with the CT20B I have a Greddy Profec to try and keep boost limited to 1Bar.
I see around 15PSI when WOT in say third gear, but as soon as I change up to fourth there is only around 2 or 3psi, unless i come off the throttle for a second or two and then when I go WOT again the boost will build to 14psi+.
Classic symptoms of a wastegate being stuck.
So I ordered a new downpipe from BRD and the design is a little different to the classic EBay ones, but still a little tight in the wastegate area.
I fitted this today and have the exact same symptoms.
So i'm asking the collective wisdom if there is maybe something else that i'm overlooking as i'm struggling to believe it is is the wastegate sticking still.
I have checked my recirc valve and it is all clean and moves fine, the only thing I wonder is maybe if the spring is a little weak, I can move this easily by hand, and is maybe staying open after activating.
Has anybody else had anything similar before
