JDM Import Rev 2 Turbo - 5SGTE build
Re: JDM Import Rev 2 Turbo - Megasquirt install. Anti lag. 2 step.
Yeah kinda just be civil and reasonable i guess. as long as you're not doing it at crazy times of the day then there isn't a lot they can do.
Good work so far
I'd definitelt recommend replacing the IC while you're at it. Helps to futureproof your build and avoid having to try and install one with the engine in place. Which is zero fun!
Magic Beans wrote:Good work so far
ebay ic anygood?
Tell her to go b0ll0x and carry on. if i've work to do, ill do it between 9am and 8pm.
Shes the one causing noise pollution with her mouth
rossonza wrote:ebay ic anygood?
Yeah, they do a job for sure. Depends what your longer term goals are and in you're wanting more boost etc. If so a decent named brand IC or CC would be better
Magic Beans wrote:rossonza wrote:ebay ic anygood?
right now it looks like ill be keeping it stock for a while, id like 300hp or as close to it as possible. However ill need to do HG and a few other mods before that. may be a while before i get chance to do performance mods. i just wondered if the ebay IC's were much of an improvement over the stock IC.
There will be some improvement. Just whether or you can justify the extra to get something decent.
Magic Beans wrote:There will be some improvement. Just whether or you can justify the extra to get something decent.
not currently with saving for a house. may have to keep stock, get it mot'd and moved into my new place then onto mods. probably keep the mrs happy as well reducing my car spend.
only just signed up to imgur for now. quick update.
popped the shops and got some supplies:
put the sill roughly into place:
Instead of trying to weld along the edge of the front edge of the sill (up against the wing) i thought id take 1 cm off the end of the new panel, and weld on a nice flat surface:
I then go onto drilling the new replacement sill ready to be spotted into place (i used all the original spot holes to line up on the new panel:
I just need to get the sill lined up, tack it in place and get seem welding where required, oh and spot all of those 60+ holes
had a HFH off rev2rich. thanks mate
now to source a hose from hell on earth
had to remove my tacked sill yesterday, doesnt quite line up as well as i had planned. waiting for a dry few hours now to get it back in place.
side note: managed to get a new walbro 255 fuel pump off ebay for £43, well chuffed
Double triple check it's genuine. There's a lot of copies out there.
androo007 wrote:Double triple check it's genuine. There's a lot of copies out there.
got an exact method to check?
http://www.ebay.co.uk/itm/toyota-mr2-mk ... true&rt=nc
is the link to the ad, i emailed them confirming its spec/what it was.
reply here:
Code: Select all
Its the HP version (high pressure) 255 litre per hour, you can just make out the part number in the pic gss341.
Well the pump came, its legit according to walbro's website. so im happy enough. just got to drop the tank now though.
Drivers sill is now fully attached
just need to get some stonechippaint on and smooth some of the spot welds then turn car around on drive and do passenger side.
will upload pics soon, welds arent pretty mind
Please excuse my welds, was my first time welding. they will be flatted back one evening this week and have some paint on them for MOT. once mot'd ill be taking it my friends with a compressor and doing a proper stonechip on the sills.
Little more progress....finally got the drivers side done (little bit of tidying to do)
final product....
god help me when i get to the wiring tidy up... looks like its had 15 different stereos wired in differently, and a turbo timer spliced in. going to be awesome figuring that mess out
final product....
Well done mate. Nice work.
Good skills, Ross
thanks guys, im obviously a beginner with all things metal work/welding.
I've had a good friend of mine guiding me along the way.
Im really happy with the results and ive learnt a lot.
hopefully the passenger side i can tackle fully on my own.
going to turn the car around tomorrow hopefully and get some pics of the mess on the passenger side
