The Predator
The Predator
So, after some absence, over the last couple of years - the 2 is finally finished.
Ive re-named the Beast to -- The Predator.
Pics and spec to follow.. some will have seen her at Japfest, Silverstone.
Going to Surrey Rolling Road with Andy, andro007, on Saturday 03.06.17 - attempting : 1000bhp from 2 MR2's - a challenge...
Should be interesting...
Jon
Jon
Re: The Predator
Pictures?????
Re: The Predator
Modifications :
Exterior :
Hydro dipped fibre glass panels :
1. Wing panels - driver and passengers from wings.
2. Boot lid, winglets and spoiler
3. Ask F40 - engine lid, fibre glass and hydro dipped.
4. Overall bodywork - in very good condition.
5. Glass T-bars - hydro dipped.
6. Glass t-bars - flocked interior.
7. Rare Ganador wing mirrors - in Carbon Fibre.
Interior :
1. Flocked dash
2. flocked door cards.
3. Replacement gator for the gearstick.
4. Seats - Corbeau Rs1 bucket Seats.
5. Cobra tailored subframes - custom fitted to seats
6. Dash 2 - re-wired looms to the rear bulk head - 2017
7. Data logger - re-wired looms to the rear bulk head - 2017.
Fuel system :
1. Oil cooler
2. Catch can
3. fuel pumps
4. Twin Goodridge -06 fuel lines,
5. ATS fuel Rail
6. Goodridge -06 series return fuel rail.
Ignition system :
1. 1ZZ COP coil packs with custom wire loom.
Clutch :
OS Giken Twin plate
Gearbox :
1. Rev 3 Turbo g/box - reconditioned - 01.01.17
2. ATS - up rated CV joints.
ECU :
1. Link G4 extreme .
2. New loom in the engine bay.
3. Fuse box moved boot - water proof.
4. Ecu - pre-programmed for different Boost settings.
5. Active knock control
6. traction control - via ECU.
Turbo :
1. ATS Racing GT35R with re-routed Tial waste gate.
Engine :
1. 2.2 - 5S-GTE - custom made engine - a one off.
2. Engine details -
3. Aquamist/ Methanol system -
4. Breather system
Cooling :
1. Mitishibo radiator
2. Custom made Intercool, designed for max. cooling efficiency - out of the rear of the boot.
3. Custom made Inlet manifold - - designed for max. air flow.
4. Throttle body - 80
5. Mitishibo fans.
6. Mitishibo shroud
Wheels/ suspension :
1. BC coil-overs - Race Series. KM seires.
2. These are 18" BK Racing 299 wheels.
They were white, but refurbished by Pristine Wheels in MK in BMW graphite grey. They were then fitted with stainless steel imitation split rim bolts and new stainless steel tyre valves. The center caps have all been painted black, with OZ center badges.
Tyres are:
225/40/18 Falken FK453 rear
215/35/18 Falken FK452 front
Wheels are all 7.5x18 - Offset 38 all round.
Date of refurbishment by Pristine Wheels: 31/03/15
Cost of refurb: £325
Cost of split rim bolts: £42
Stainless Tyre valves: £19
Tyres purchased 30/04/15 and cost: £360
With tyres only purchased last year, they're still in good condition with plenty of tread left.
Total cost of refurb (wheels refurbished, split rim bolts, stainless tyre valves and tyres) = £746
3. Uprated Droplinks
4. Custom rear strut brace.
5. Polyutherane bushes all round
Brakes :
1. Big brake conversion
2. Front discs : 325mm diameter.
3. Braided hose lines all round.
4. DOT 4 fluid.
5. 4 pot front GT4 brake calipers.
6. All Calipers refurbished and powder coated/ painted - 2015.
Exterior :
Interior :
1. Flocked dash
Fuel system :
1. Oil cooler
2. Catch can
3. fuel pumps
5. ATS fuel Rail
Ignition system :
Clutch :
OS Giken Twin plate
Gearbox :
ECU :
Turbo :
Engine :
2. Engine details -
4. Breather system
Cooling :
5. Mitishibo fans.
6. Mitishibo shroud
Tyres are:
Brakes :
4. DOT 4 fluid.
Re: The Predator
Theres probably more but that'll do for now..
Re: The Predator
Good to see it's resurfaced
Re: The Predator
Engine details - this engine WAS built by Simon at Predator Performance, Southampton, 2017.
a. 5s block from ATS - USA - ported and gas flowed.
i. - Toyota Camry 2.2ltr 1999 Engine Block with crankshaft, bored, honed, decked, oil squirter fabrication & thermal treatment
- Rev1 Turbo Sump and Pick Up
- Rev3 Turbo PORTED Head, surface grind, re-shim
- Custom Made aftermarket Cams - one of Kelford cams from New Zealand.
- Adjustable timing pulleys
- HKS Stopper Head Gasket 1.2
- Oil pump and gasket.
- Custom idle control bracket.
- Custom pipework to the intercooler and return.
- Thermostat - Race - low temp.
- Inlet and Outlet Valves - over 100 shims were measured for clearance and only the closest 16 were used.
- Kevlar Cambelt HKS
- Hydraulic tensioner
- Idle bearing
- Fidena flywheel 5S.
- Fully balanced and lightweight crank.
- D-1 spec, Radiator cap - 1.2bar.
- Cambelt Tensioner Bearing
- Alloy Alternator Pulley
- Phenolic Rev3 Spacer
- Standard cast exhaust manifold, extrude honed and thermal treatment
- New King bearings all round, ceramic coated
- Wiesco 87.5mm Forged 8:3 compression pistons - custom design
- Eagle Forged rods
- ARP Main, Head and flywheel bolts
- ATS GTX3576R turbo unit with 2.5bar tial wastegate V band
- Downpipe with re-routed screamer back to downpipe
- All new engine gasket set - throughout.
- Custom single exhaust through a 3 leading to a 4 tip.
- Exhaust manifold - internal ceramic, external base ceramic plus Black Satin coating applied to cast manifold.
- EXHAUST manifold upgraded to a Sports manifold this weekend - 27.05.17
- Wideband gauge
- Exhaust EGT Temp sensors in exhaust manifold
- Top feed injectors 1000cc
- ATS fuel rail, top feed
- Fuel pressure regulator
- Catch can.
- Custom Rev 3 head steel cover.
- Walbro 255lb Fuel pump, in tanks then X2 fuel pumps 044s in boot of car and -06AN lines
- Water injecton system to help supress detonation
- Oil Micro filter 15mm and sandwich plate
- New Ignition components - COP + ECU.
- 3 manual exhaust system cut-off valve kit.
- New water pumps.
- Oil - Millers 10/ 60
- new high lift springs.
- Mishimoto magnetic oil drain sump plug
- Race Technology - DL1 mounting kit
- Race Technology - 2m serial lead
- Race Technology - DL 24way Connector
- Race Technology - Fuel/ Oil Temperature sensor
- Race Technology - Fuel/ Oil Pressure sensor
- Race Technology - Push button x4
- Race Technology - 2 channel 315Mhz wireless Transmitter/ receiver - on steering wheel.
- Sparco Two button steering wheel switch assembly.
- Idle bearing
- Eagle Forged rods
- Wideband gauge
- Catch can.
- New water pumps.
Re: The Predator
Cheers bud...
Rolling road 03.06.17.....
Re: The Predator
That's quite a list!
Hope the RR goes well
Re: The Predator
Magic Beans wrote:That's quite a list!
Cheers bud,
Also, glad to see you back on it...
Re: The Predator
I completely fell off the wagon this time. Just when you think you're clean, they get their claws back into you
Re: The Predator
Absolutely stunning mate,impressive build there and a lot of time and thought gone in to your predator
Tuned in
Tuned in
Re: The Predator
Lots of good Mr2's coming out of Simons garage now.....
Cant wait John better hit those numbers or it'll cost me lunch
Re: The Predator
Impressive spec mate, looking well. Good luck at the RR.
Re: The Predator
Cheers bud, amazing how it all comes together- obviously with a different specialist.... lol
Re: The Predator
Long time no see, John! Hope you're well Good to see you putting up a build thread. Impressive parts list you've got going. Looking forward to results from RR
Re: The Predator
MR2 Turbo Boy wrote:[/URL]
Now now now, how's that going to work with the weekly shop at Aldi??
Re: The Predator
aussieGT wrote:MR2 Turbo Boy wrote:[/URL]
Lol...
