I've seen a hks fcon plug and play chip on ebay, does anybody know what sort of gains can be got from one of these as I would like to perk my car up a little but not to much.
If any body has got any links or stats for one that would be great.
Cheers Phil
HKS fcon chip rev2 turbo
Re: HKS fcon chip rev2 turbo
What have you done to your car so far? Very rarely is there a ECU that you just plug in and play and get gains,
Unlike mapping a more modern car like say a Golf GTI, most MR2s are not in the same state of tune as most Golfs are
As far as the that ECU i'd say save your money
http://www.ebay.co.uk/itm/hks-fcon-mr2- ... Sw241YmOG1
If its this one then yes it is plug an play with regards to wiring but will need to be mapped to get the best out of it
Yes that's the one, I'm toying with either getting one of them or a electronic boost valve.
Car is pretty much stock apart from a blitz filter, I've refitted a stock exhaust system bur if needs be would put an aftermarket one back on.
Get yourself a decent electronic boost controller and have some fun!
If you buy an ECU, it'll need mapping (if you like your engine) and that's a lot of cash to spend on such a mildly modded car.
You could really do with a free flowing exhaust to help the car breathe - you've done the filter so that's good.
Buy a boost controller, turn up the boost a little, enjoy
That's what I'm thinking , I don't want silly power I just want it to feel a little bit willing to go.
Save your money. Most of these dont come with the PFC F-CON absolute pressure sensor. Whether you can use the Stock one i don't know.
Best option to go is REV3 fuelling and get rid of the AFM. Bigger injectors so safer on up'ing boost and no need for a FCD
Doesn't look like it has the MAP sensor with it. The 3 Bar GM sensor works in place of the original one. That's what I use in mine. Was £30-£40 from America.
There's a switch inside to change the amount of fuel delivered, I set mine up with my wideband, never had it on a rolling road so no idea what difference it makes. Made a lot of changes at the same time so can't go by feel either.
Bit of info here along with install manual - http://1jzmerc.com/hks-faq/hardware/pfc-f-con
I'd say it's very overpriced, especially without a MAP sensor, but then look what people pay for a Blitz Access ect.
ct20b + exhaust + downpipe and EBC are the best bang for buck modifications for an MR2 turbo. Disable the boost cut and you can run 12s.
