[quote="Adam86"]Unfortunately I believe the block to be cracked.
Covered 2500
- 3000 miles since complete rebuild with the following parts
86mm Forged Wosner pistions 8.0-1
ACL bearings throughout
New cam belt and bearings
New oil and water pump
New gaskets and seals throughout
Asking for
£500 which is less than the pistons alone cost.
With the oil and water pumps removed I'll take
£400.
I also have a rev2 block with 86mm bores to suit the wosner pistons as I was going to re-block the engine before I decided to go with a caldina 3sgte.
Not wanting to be negative but I just dont get this add?
Your selling a forged block, but the blocks cracked,
Your selling ACL bearings but I would never re-use bearings especially if they have to go into another block.
Then you say this is less than the price of new pistons, well yes second hand pistons would most definitely be less than the price of new ones.
Gaskets
& seals arnt really re-usable in a high performance engine
Genuine question am i missing something
Kennym
