As part of my rebuild, I'm wanting to monitor as much as possible in terms of temperatures etc. All will supply my LINK G4+ Extreme, some will go on to a gauge for quick visual checks too.
With my water temp sensor, I'm getting conflicting advice about where to put it in the coolant's journey. For those of you who have them, where are the senders fitted and can you share photos?
Cheers,
Mark
[Mk2] [Turbo] Where to add water temp sender?
Re: [Mk2] [Turbo] Where to add water temp sender?
i can only go off what ive seen, but usually on the large coolant pipe fitting to the coolant elbow. this is directly from the radiator where it enters back into the engine.
but interested to hear where others have put it.
EDIT;
oh just to add, this location is also where the oem ecu and oem temp gauge gets its temp readings from.
EDIT;
I thought the stock coolant temp sensors were on the exit of the engine and before flow to the radiator?
Using this position means you are measuring the hottest point (in theory) of the system, which is probably more useful than the temperature before it goes into the engine.
Another useful point would be to measure on the cool side of the radiator, then you could use this to control the rad fan(s)- so if the temps out of the rads start to climb, switch fan on kind of thing.
sorry i didnt mean to insinuate it was an exit or entrance point, more the point where oem measured from and where it mates to the engine.
ashley wrote:I thought the stock coolant temp sensors were on the exit of the engine and before flow to the radiator?
I like the thought process here. I think I'll go with the stock location initially - might just be room to tap a second sensor into that elbow, if not I'll likely use an adaptor in the hose.
Thanks chaps
