has anyone found this to be a broken wire/connection anywhere?
I can't see anything so assuming it is the faulty sensor.
jimGTS wrote:If the error has been stored, it will always be there until you reset the ecu.
Whether or not you go over 3k rpm.
If sensor is blown, the eml will stay on when over 3k rpm when there's some engine load.
