Spot light bulb
Spot light bulb
What's the type of bulb used in the spot light, I want to order a set of yellow bulbs ![thumleft :thumleft:](./images/smilies/icon_thumleft.gif)
Re: Spot light bulb
Pretty sure they are H3 bulbs.![](./images/smilies/spacer.gif)
Re: Spot light bulb
garygt4 wrote:What's the type of bulb used in the spot light, I want to order a set of yellow bulbs
Spot lights?
![Think :-k](./images/smilies/eusa_think.gif)
Re: Spot light bulb
Fog lights ![thumleft :thumleft:](./images/smilies/icon_thumleft.gif)
- IMOC Moderator
Re: Spot light bulb
![Image](https://i.imgur.com/MHtSyfF.jpg)
Hail Cosmos Eagle Rev 5, 1998
RIP White Eagle Rev 1, 1991
Re: Spot light bulb
There's two different kinds and can be tricky to match even
From toyota with a chassis number,I'd take it out and check it against new one
Too weird to live, to rare to die
- IMOC Moderator
Re: Spot light bulb
ahh yes the dreaded H3C on import turbos
/ steering fogs as i recall
heres something about them![](./images/smilies/spacer.gif)
http://www.mr2oc.co.uk/forums/41/159566.html
regards
regards
- IMOC Moderator
Re: Spot light bulb
Also the
"Yellow" OEM fogs as per the ones on my rev1
"White Eagle" thats being broken, are not yellow bulbs they have a yellow cover for the bulb
you can see the colour cast from the internal yellow bulb cover
![Image](http://i1135.photobucket.com/albums/m628/brianwhiteagle/20160820_143410_zpsqazo9usg.jpg)
Re: Spot light bulb
You only have to add an earth wire to use H3 instead of H3C, here is the one I added on mine
![Image](http://i536.photobucket.com/albums/ff327/madbasshunter/Purple%20Haze%20MR2/2016-07-13%2011.44.19_zpsnc0pqwwk.jpg)
H3C bulb is still in place as I forgot to take a picture when fitting the H3s
RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
Re: Spot light bulb
wilkie senior wrote:Also the"Yellow" OEM fogs as per the ones on my rev1
[url]http://i1135.photobucket.com/albums/m628/brianwhiteagle/20160820_143410_zpsqazo9usg.jpg
[/URL]
Are these for sale?
- IMOC Moderator
Re: Spot light bulb
indeed
if your going to JAE and want them I can bring them
http://www.imoc.co.uk/forums/viewtopic. ... highlight=
