mr2nut123 wrote:Charged wrote:Refurbished CT20 with 2 year guarantee bought from TCB this morning for£450 next day delivery.
Amazing service as ever
That's a great price!Is that a brand new rebuild with stock internals?
craig wrote:mr2nut123 wrote:Charged wrote:Refurbished CT20 with 2 year guarantee bought from TCB this morning for£450 next day delivery.
Not a bad price that.The
£612 I paid was for a full recondition
(came back looking like a brand new turbo), steel wheel/shaft and 360 degree thrust washer to replace the 270 degree stock item.
So essentially, an upgraded CT20b to replace the weak parts of the stock item.
Does it produce more power than stock Craig?Did you get a before and after?
I'm due a clutch soon, so i'm going to replace with one good for 400hp for future proofing.
What is safe maximum power from a rev3 without forging and spending a bomb?
I was thinking, a slightly uprated CT20 would be a good route as it would work with stock ECU too.
Fitting a 360 degree Thrust Bearing increases the reliability of your turbocharger and allows a safer way of running high boost pressures.The thrust bearing is under heavy pressure when the turbocharger is operating, the larger surface area of a 360 thrust bearing
(as opposed to a traditional 270 degree unit) is better equipped to cope with these axial loads.
A 360 degree thrust bearing is recommended if you intend running more than one bar
(14.7 psi) of boost.
Running high boost on a standard thrust bearing can lead to premature turbo failure and a big bill!
Charged wrote:Arrived today..
very shiny, brand new and generally sparking.
Steel shaft and wheel to boot!
QUOC2008 wrote:turbo techniques maybe upgrade it aswell to a hybrid..
more power
They did mine in 2015, although I chose the upgrade option- the difference to yours being a larger compressor and turbine wheels, housing machined to match, with incotinel metal internals.
