Hi all,
I have an intermittent issue with my Rev5 NA
(UK car so Gen3 3SGE), as it's intermittent it's a bit tricky to track down.
Sometimes while pulling away gently with a small amount of throttle, it will misfire/hesitate at
~1500RPM.
It's almost as is the ignition has been turned off for a split second.
It doesn't stall though.
It has only ever happened when the engine is hot, I cannot see a pattern in the conditions leading up to it though.
Another issue
(again very intermittent) when maintaining a constant speed in 1st, 2nd, or 3rd at
~2000-2500RPM it will do a similar thing
- misfire/hesitation.
This will only happen at very slight throttle positions
- if you apply more throttle in these problem areas it's fine.
It runs fine above 2500RPM or so.
Fuel economy seems pretty normal, and there's no loss of power at wider throttle openings.
O2 sensor seems to be oscillating as it should, fuel trim is at 2.51V which fine.
I can't find a pattern to this at all, which makes it tough to work out.
I've tried two TPS's
(both calibrate correctly), though the 2nd one was an unknown to me so it is possible that the 2nd TPS was faulty.
Both that one and my original calibrated and tested correctly against the BGB values though.
I have one more spare to try so as it doesn't take long to swap
/ calibrate I'll try that one as well.
ECU Temp sensor has been replaced.
O2 sensor has been replaced.
ISCV has been cleaned out.
Most of the vac lines have been replaced.
HT leads, plugs, rotor, distributor cap are all recent
- I would expect these to break down at high load
/ high RPM if they were a problem, not in the conditions above! Edit
- tested HT lead resistance, all well within spec.
No damage to any of the leads.
Tested ignition coil against engine manual values
- primary and secondary are within spec.
Mechanical timing is correct.
Ignition timing is advanced a few degrees
- car has been like that since I bought it 2 years ago.
For the purpose of ruling it out I'm going to put it back to 10 degrees.
If it is this, I'd like to know why it's become a problem now though.
Compression is good
- 210PSI+ across all cylinders, all cylinders within range of each other.
Going to work through the troubleshooting section in the 3SGE workshop manual tomorrow, but in the mean time, if anyone has any ideas or has fixed a similar issue then I'd like to know!
