Davsurfa wrote:The timing marks were all lined up,silly question but could it be 180 out? There are only one set of marks on the cams
Ryan S wrote:Are you 100% sure the timing isn't 180 degrees out? I've seen this many many times on here in the past.
Davsurfa wrote:But if I turn the crank 180 the timing mark won't line.
Davsurfa wrote:LEGEND!!! Thank you for that, now all I've gotta do is strip it all down again
