Hi all.
I've got a strange problem on my 93 rev 2 turbo and it's been like this since I bought it.
When you first turn the car on it will idle at low revs
- around 800rpm.
If it's cold then this causes the engine to struggle and sometimes die, I need to give it some revs for a couple of minutes to get it warmed up enough to keep going on its own.
Then, as the engine warms up, the idle speed slowly increases until it gets to about 1,200rpm when fully warm.
The idle speed is basically doing the exact opposite of what it should be doing, 800rpm when cold and 1,200rpm when warm instead of 1,200rpm when cold and 800rpm when warm.
The ISCV has been thoroughly cleaned out but it wasn't particularly dirty to begin with and there are no faults displayed.
Does anyone have any suggestions for what could be causing this?
