Upgraded Engine Parts
Re: Upgraded Engine Parts
That sounds like a whole world of pain for no good reason.
Why not just get some parts that are designed to fit together?
kaiowas wrote:That sounds like a whole world of pain for no good reason.Why not just get some parts that are designed to fit together?
Agreed.
Sometimes there is a reason why something has never been done.
They do all fit together, they are all from the 4AGE.![](./images/smilies/spacer.gif)
Found all the bits I need now, so it's all good.
Why be the same as everyone else and try something different.![](./images/smilies/spacer.gif)
Paul Woods is known for that
To be fair it's usually in the name of a huge power increase, i think what the lads are saying is you're doing a lot of work for really no gain when there are simpler options.![](./images/smilies/spacer.gif)
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport7/wsnewlogo.jpg)
Are you using the block with the 10.1:1 pistons?SuperRedMR2 wrote:Have you know anyone to do a smallport piston, smallport head, small port fuel rail, bigport injector/inlet manifold, 3-rib block, 20v Exhaust header, build? lol
I've heard that stock bigport cams are slightly more aggressive than stock smallport cams, so if you've got a smallport head you may want to consider swapping the cams around.
- Lauren
- IMOC Committee
Skaughtto wrote:[
Only the earlier blue top cams are more aggressive.
2020 GR Yaris
- Circuit Pack ![lover :lover:](./images/smilies/jef_icon_lover.gif)
Hi mate,
I am the one you have asked for postage about on eBay![Smile :)](./images/smilies/icon_smile.gif)
I've found some smallport pistons in the USA I am using instead of spending
£500 on Pistons from this country.![](./images/smilies/spacer.gif)
I've read that too recently about big port cams in a smallport head but I've already got aftermarket cams I may be using.![](./images/smilies/spacer.gif)
- Lauren
- IMOC Committee
Worth remembering the later blocks
(as found on the small port engines, so AE92 on) have oil squirters
for the pistons and a bit more strengthening around the crank.![](./images/smilies/spacer.gif)
2020 GR Yaris
Finding a bare block of that age is very hard.
Not even anything for sale on the AE92 owners club I am now subscribed to.![](./images/smilies/spacer.gif)
- Lauren
- IMOC Committee
Really? ![](./images/smilies/spacer.gif)
If you know people in the MR2, AE86, AE92 scene, it's not that hard.
I seriously doubt it'd take more than a few weeks to come up with a late spec 4AGE if you put your mind to it.
You want to check out the AE86 scene.![](./images/smilies/spacer.gif)
2020 GR Yaris
I'm on there too.![](./images/smilies/spacer.gif)
None of them run later blocks.![](./images/smilies/spacer.gif)
Plus one got no money to buy a block even if one came up.![](./images/smilies/spacer.gif)
SuperRedMR2 wrote:
I've found some smallport pistons in the USA I am using instead of spending£500 on Pistons from this country.
Last I knew brand new OEM pistons could be bought from Toyota for just under
As for the block, even if you can't source an oil squirter block, at the very least get a 7 rib block.
I've been rest assured the 3-rib block is fine, but thank you for your concern.![](./images/smilies/spacer.gif)
As the block and head and all other items will be installed prior to installation, we will be able to see where any modifications will be necessary instead of having to bodge at the last minute.
I'm not going to respond anymore about being told to start with the correct parts, as this is my choice.![](./images/smilies/spacer.gif)
- Lauren
- IMOC Committee
I think people are just trying to help.
Building an engine properly is going to cost a serious amount, you have to add the machining needed and all that.
Even if you do all the assembly yourself, parts will cost a significant amount.
2020 GR Yaris
I've calculated all the costs and my best mate who has been a qualified mechanic for 12 years is doing it for me for a minimal labour cost.
He's worked at Volvo, Land Rover and now Vauxhall.
He also installed a PW 4AGZE supercharger engine into his MK1A
- I'm in safe hands here.
I'm using the 42mm crank, so I don't know where you got the info from that I'm using a weak crank.![](./images/smilies/spacer.gif)
There is a chap called Dick Bassom who is now a good friend of mine, who has assured me that the block is fine and it's always the crank and rods that give way first.
I'm not using the weaker rods and crank.
The block has been thoroughly checked out and it is in pristine condition.
The head has never been touched and this has been verified by measurements and working out it's volume
- handy if I was to use the head.![](./images/smilies/spacer.gif)
I'm not cutting corners, I am buying correct gaskets and parts.
It may seem that I'm cutting corners because I'm using parts from a later engine but I'm just trying to get the most out of it all.
The smallport is better for tuning than the bigport
- hence why I'm using it.
People moan about the lack of tuning for the 4AGE but as soon as an opportunity comes along, negativity all round.![](./images/smilies/spacer.gif)
Knowing what the car is going to be used for and what the hp goal is would help to determine if the 3-rib block is ok or not.
From what I've read, if you are not installing 272+ cams, increasing the redline, and your hp target is around 180 or below, the older block is adequate.![](./images/smilies/spacer.gif)
Fitting the smallport head complicates things a little bit.
I'm doing a similar build and am going to use a ported bigport head for simplicity.
Right now I'm looking at using a 3-rib block, just because I have a spare, but if I could find a AE92 short block I would probably use that instead.![](./images/smilies/spacer.gif)
Hi mate,
I'm working with what I have got, hence using a 3-rib block I was given.
The interior of that engine is immaculate with the crank all coming in to tolerance.
Everything is as it should be.![](./images/smilies/spacer.gif)
I'm not increasing the redline, installing 272+ cams, so yes you can see I'm sticking to what it can put up with, which'll be lower than 180
Hello,
I'm owner of MR2 MK1a with 7RIB 4AGE modified engine
(currently 176ps).
This project was based on 4RIB engine with CatCams 267/262 cams, and Hayabusa 99-07 ITB
+ Keihin 260cc injectors.
During the tune-up one of the bearings just didn't make it and engine had to be replaced for stronger 7RIB with OEM 42mm crank and rods.
The goal is to use 291/285 cams, Honda S2000 injectors and get somewhere close to 200ps.![](./images/smilies/spacer.gif)
IMHO you should think of getting 7RIB engine.![](./images/smilies/spacer.gif)
