Mk1 rubber door seal
MegatronUK
Post by MegatronUK »
Looking for either a pair of new door seals (the ones with the metal plates in the ends that start near the lock, go down the side of the door, along the bottom and then up to near the mirror), or a part number to take to Mr Minories Toyota esquire to get some ordered.
Someone has got to have replaced these... the metal inserts all seem to drop to bits!
kevin..in
Re: Mk1 rubber door seal
Post by kevin..in »
if you're going to a toyota main dealer then all you should need is your vin no they should be able to find the part no. from this
j0nathan
Post by j0nathan »
When you do get a price/part no. be so kind as to post it if you would. I am sure there are others on the list that would appreciate the info, myself included.
Thanks,
Jon
