Anyone know the measurements for a mr2 mk2 rev 2 3sge UK throttle position sensor with a feeler gauge and multimeter !?
Kind regards
Charlie
Tips gauge settings etc for rev 2
Re: Tips gauge settings etc for rev 2
its in the online bgb ... ive helped people before with this ... getting the muti meter prongs into the sensor and doing the feeler gauge its tricky ... two man job for sure ... good luck
Have a look through should be in there ... http://mr2.ie/mr2/bgb/mk2/mechanical/in ... nical.html
Probably in electrical ... http://mr2.ie/mr2/bgb/mk2/electrical/in ... rical.html
If i had the time id find it for you
2mad wrote:its in the online bgb ... ive helped people before with this ... getting the muti meter prongs into the sensor and doing the feeler gauge its tricky ... two man job for sure ... good luck
Best dodge I found was to make up a short jumper lead with chock block at one end to clamp onto the multi meter prongs and small spades at the other to attach to the pins on the sensor. Still a bit fiddly geting the spades on by "feel". But it does make it a lot easier single handed
Paul
Pauln wrote:2mad wrote:its in the online bgb ... ive helped people before with this ... getting the muti meter prongs into the sensor and doing the feeler gauge its tricky ... two man job for sure ... good luck
Paul
I had a spare tps connector ... did the same thing ish .. like this ...
Anyone know of anyone local around Lincolnshire that can do it as I have no time tbh
