Power steering problem
Hi, I'm having trouble with my power steering it comes and goes but seems to be gone alot more than its there, is there anything that gives trouble, someone told me the relay under bonnet?it's 98 rev 5 na. thanks in advance
Re: Power steering problem
the relay contacts are a likely culprit, try turning the ignition key on and off a couple dozen times, usually cures the problem, short term at least
Yeah once the key trick doesn't work anymore you will probably hav to check the brushes on the electric pump. If they are knackered it's time for another pump.
Cheers guys il try that
Al-sw20 wrote:Yeah once the key trick doesn't work anymore you will probably hav to check the brushes on the electric pump. If they are knackered it's time for another pump.
When the key trick don't work its time to replace the relay not bushes in the pump.
But then you could always swap the bushes for new ones instead of replacing the pump.
You could if you could find some .
Anybody know where the relay is located?
Comes and goes? can you be more specific, does the power steering light come on at all?
The relay not making usually happens when you turn the ignition on initially not randomly when driving as it stays energised. The relays is on the RHS of the engine bay as you face it IIRC it's a cylindrical shaped relay and secured to a rubber mount of some sort.
Probably worth checking your fluid level as well.
Hi mate
I had this problem where the PAS would stop working every winter (and usually get better once the weather improves!). There is a bodge where you connect two wires to the same relay terminal. However, I always felt this was a bit too much of a bodge so this year I finally replaced the relay and the problem has been solved for about 3 months.
The stock relay is available on the net, but the cost is really high, so I followed a guide here:
http://www.mr2oc.com/showthread.php?t=355400
I just replaced the relay with a standard 70A type. I've got this one bookmarked, so suspect it might be the one I used:
Panasonic CB1aH-M-12V (M for mountable):
http://uk.rs-online.com/web/p/non-latch ... s/8113097/
Then you just need a few suitable crimp connectors (2x 6.3mm and 2x 9.5mm in my case) to replace the ring connectors used on the standard relay.
It's a nice easy job. I hate electronics and even I managed it!
