What new turbo?
Matsumoto
What new turbo?
Post by Matsumoto »
Sooo today the car started running funny and after investigation found the turbo has excessive shaft play..
What do you think? New turbo? Standard or updated? Hybrid? Or get the old one fixed. And where is best?
shinny
Re: What new turbo?
Post by shinny »
How about telling us what the car is and which mods, if any, you have? And what kind of car you're looking to build?
Matsumoto
Re: What new turbo?
Post by Matsumoto »
sorry peeps, well being in the mr2 forum it's a mr2, obviously a turbo and it's a mk2.
Mods are :-
De -cat
Performance air filter
HKS FCD
Manual boost controller
And I believe that's it engine side.
As for what I want from the car....well cost is more of the issue as it's the daily driver so what ever is most economical.
archangel
Re: What new turbo?
Post by archangel »
Which mk2 rev do you have?
Revision 1 (12/1989 to 11/1991)
Revision 2 (12/1991 to 11/1993)
Revision 3 (11/1993 to 06/1996)
Rev1 Tubby, Garrett GT3071R, Motec M4 EMS, 880cc delphis, Rev3 turbo port polished built head/cams/titanium retainers, shim under buckets, HD springs, etc., rear bumper mounted intercooler, and vanilla air freshener.
shinny
Re: What new turbo?
Post by shinny »
Matsumoto wrote:HKS FCD
Well, this would generally imply you have a rev1 or rev2. Therefore I expect you have a CT26 turbo that has let go. A replacement CT26 is the easy a cheapest option. A CT20b conversion is a nice mild upgrade while maintaining OEM parts and is probably the option I'd suggest for you as the cost is still relatively low.
Matsumoto
Re: What new turbo?
Post by Matsumoto »
Sorry guys Rev 2 :)
EarL
Re: What new turbo?
Post by EarL »
Absolutely on the money :thumleft:
Matsumoto
Re: What new turbo?
Post by Matsumoto »
Brilliant that's exactly what I was after...I've found one for 200 all in (used) sound about right? Thanks again guys
shinny
Re: What new turbo?
Post by shinny »
Matsumoto wrote:Brilliant that's exactly what I was after...I've found one for 200 all in (used) sound about right? Thanks again guys
One what? CT26 or CT20b? (Do NOT get a single-entry CT20, it won't fit)
Matsumoto
Re: What new turbo?
Post by Matsumoto »
No it's a direct replacement, CT26 with manifold.....
androo007
Re: What new turbo?
Post by androo007 »
200 should be a ct20b, I'd say 150 for a 26. But supply and demand etc etc
mr299ron
Re: What new turbo?
Post by mr299ron »
Where do you guys get new turbos from? I've found Fensport to give a good deal, as they'll give you £150 for your old turbo. So £480 for a reconditioned/new CT26. Good or bad?
