As above that radio won't work in my Rev 1 turbo, any specific reasons anyone can think of?
There is constant power coming through yellow wire as should.
any ideas what's causing it not to get power to turn on?
kurkjones wrote:It's in title.![]()
Xtrons td714sg- 7" double din touch screen etc.
It's got a fuse near where you plug the loom into
RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
