bit more progress
*Fully reworked engine harness; removed every unneeded wire/connector including the fan control ecu.
Diag and map sensor rewired into the boot
*FPR, fuel return line and expansion tank in the boot
*Air temp sensor, ABS wiring, boost line rerouted to the inner archs
*removed and now no ports for pcv, idle valve and sensor for the custom air filter
*Body harness also over the inner arch
*Charcoal canister and its hardlines, a/c, iscv coolant lines, tvsv bits, engine mount plate, engine hook removed along with the catchcan support and dump valve hardpipes
*Rerouted coil pack and ignitor
*Aerial and loom plus rear speaker wiring gone
*Rerouted engine lid cable
I have a few more ideas, but just want to drive it now once I clean up the odd w/i and engine lid fan wires/relays
cleaned up starter
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/DF2472DD-B8AF-403C-A389-FBCFFE6F6E5E.jpg)
new location for boost hose, cabin to boot wiring, ABS wiring and engine lid cable
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/A676F1BA-53B1-4CE0-949C-445FEE3B0637.jpg)
cable into the bay
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/14D47A04-E3D4-48D5-BA91-0208F58A03DC.jpg)
new custom fuel rail line
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/BB63E7E5-2FB6-4568-AA95-C04F1FABEE33.jpg)
new location for fuel pressure reg return line and air temp sensor
(over arch and back into the bay along with the body harness)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/2429F3F5-505E-433E-A8C4-6466501762C2.jpg)
thought i had a dead cluster, so replaced capacitors, but turns out id wired tacho wrong from the fuse box
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/2689BA03-F278-4524-BB99-EDC698302B5D.jpg)
getting bare, but still dirty, ha
new location for coil and igniter on extended wiring
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/3054FE3B-4C19-4DE1-B6CE-B8D5CF6C1CD3.jpg)
fuel pressure reg new location along with the diag port and map sensor
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/BB0B7DCB-81C6-47A6-916B-580C1F9401B9.jpg)
new harness configuration after countless testing and wire extensions
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/CB3011C2-5B6F-44C7-AB96-9D676BE203F8.jpg)
car up and running!
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/AE9D0525-8D52-4159-8859-4C9CE981AC39.jpg)
new sparse drivers area, no more diag/map sensor, and only wiring for the o2 sensor coming out the cover now
(in addition to no more wiring for a/c, fan, cat temp)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/2EE9B1BB-C89F-4C9E-9778-A4E0C2927D26.jpg)
dirty still!
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/9F7C7E90-4AA5-4CCF-A04C-CB16D7DAAED8.jpg)
current boot configuration
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/1253EA59-81CA-4C4C-B083-CE06E24BABBF.jpg)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/8E11B32C-CF60-4658-8C89-31C5EDEDA8E4.jpg)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/FE3BB03F-6604-4D25-9D73-5497E10B06AD.jpg)
still some hosing to sort
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/31459DEC-2CB5-4B93-8392-6369A8656B65.jpg)
