Any ideas where I can get it cheaper??
abs4263 wrote:Getting that fuel smell in the cabin, I've put up with it for a while now but Its time to get it sorted, I've rang Toyota and they've quoted me£45.55 inc VAT i read somewhere that it should cost around
£30.
Tony jinxy froude wrote:Ok, i'll go through this again.Buying a new vapour trap will not cure your problem
& you will be throwing nearly 40 quid away.
I have this info on good authority that Toyota realised they had this problem way, way back
& their only cure was to take the pipe off of the passenger side of the vapour trap where it goes into the chassis
& route a longer section of pipe facing towards the rear of the car, this can be attached using cable ties to the top of the handbrake cable, this is perfectly safe as any fumes exit to the rear of the car
& not into the engine bay.
Tony jinxy froude wrote:Any good motor factor will supply enough pipe to do the job, make sure its fuel grade pipe though, if nesessary remove the little piece of pipe from the end of the vapour trap where it goes into the chassis( passenger side of vapour trap)
& take it with you to the shop, they should be able to match the diameter for you.
Jinxy
If i get a chance today i will take a piccy of it on my own car.
Porl'' wrote:Tony jinxy froude wrote:Ok, i'll go through this again.Buying a new vapour trap will not cure your problem
I bought the fuel vapour trap and it didnt fix the problem.Is adding the new pipe easy to do and where would you buy a pipe long enough to do this?
thanks
Paul''
