When I first bought the car, it had a HKS EVC-S and HKS FCD installed.
I decided that I would like to take the car back to almost original spec and so I began removing some of the aftermarket parts.
I reconnected the pipe of the turbo housing, to the left nipple of the actuator.
Following this, I went for a test drive and noticed that it would only boost to 0.5 bar.
I then tried connecting a manual boost controller which I fitted in between the turbo housing and the left side of the actuator.
I then remembered that the TVSV had to be blocked on the right side of the actuator, which I then did.
I found that adjusting the boost controller had no effect whatsoever after this.
I checked the blue plug and pipes under the inlet manifold and found them all to be connected as they should be.
The car currently drives fine, with no smoke or hesitation of any kind but only boosting up to 0.5 bar which it holds throughout the rev range.
Any help on the situation will be greatly appreciated!!
