Is there a way to get them to go down without turning off all my lights completely?
thomp1983 wrote:Think there's an article in the knowledge base for this you need to cut one of the wires at the relay
RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
Gazza_DJ wrote:thomp1983 wrote:Think there's an article in the knowledge base for this you need to cut one of the wires at the relay
Yep.Better off installing a small switch so you can revert back to normal behaviour easily though.
