How are you finding the working of your sensor
Final piece of the chargecooler Jigsaw arrived today
Just need to weld in the BOV adapter and weld in the valve i bought to drain any excess air from the core.
Also build a bracket to hold the core in place, no biggie, then fit it
I don't suppose it matters which way round the water pipes are attached, i think i am going with the cold water going into the left pipe
(outlet from chargecooler) and exiting from the air intake side, works best in my head, not by much though, lol
Quick mock fit, mainly to figure out where to put the mounting bolts and to make sure it all fits, everything went swimmingly, even cleaned the rear window
I am not sure what to do with the airfilter though, the blitz is only 3" in diameter while the older k and n is 4".
I would be placing the blitz as far down towards the air intake hole in the cars body and maybe using some 3" s/s pipe and then a 4" to 3" reducer to connect it all up.
Will this be ok for my power goals and 1.8 bar of boost
and this is the current k and n filter
closed end while the blitz is capable off pulling in loads of air from the end.
And my latest purchase, although smaller than i anticipated it actually works really well, an IMOC protector.
Could always buy an Arc box but i don't think that will be necessary
Thoughts on reducing the air filter intake size
