[Mk2] [Turbo] Can anyone help me identify this smoking issue?? VIDEO
alex687
Re: [Mk2] [Turbo] Can anyone help me identify this smoking issue?? VIDEO
Post by alex687 »
I had bad creep issues with mine. Had to fit a restrictor ring at bottom of downpipe which did fix the issue. Would be nice to not need that once I get the turbo sorted. Should I be looking at a different/clipped turbine or porting the wastegate or both??
bobhatton
Post by bobhatton »
alex687 wrote:Got my "standard" ct26 back from TT today and thought I'd share with you a load of pics.
Image Replaced With URL For Quote http://i1300.photobucket.com/albums/ag8 ... swsjts.jpg
Image Replaced With URL For Quote http://i1300.photobucket.com/albums/ag8 ... ano4gr.jpg
Image Replaced With URL For Quote http://i1300.photobucket.com/albums/ag8 ... ekj7dd.jpg
Image Replaced With URL For Quote http://i1300.photobucket.com/albums/ag8 ... 6eqkij.jpg
Image Replaced With URL For Quote http://i1300.photobucket.com/albums/ag8 ... zu6mnd.jpg
The perspective makes it look wrong but the verniers are near enough inline with the inner diameter of the exducer.
Image Replaced With URL For Quote http://i1300.photobucket.com/albums/ag8 ... nycoif.jpg
Image Replaced With URL For Quote http://i1300.photobucket.com/albums/ag8 ... 112e9h.jpg
Image Replaced With URL For Quote http://i1300.photobucket.com/albums/ag8 ... quhqer.jpg
Image Replaced With URL For Quote http://i1300.photobucket.com/albums/ag8 ... hb7pcu.jpg
Image Replaced With URL For Quote http://i1300.photobucket.com/albums/ag8 ... gsjxdf.jpg
Image Replaced With URL For Quote http://i1300.photobucket.com/albums/ag8 ... d1c1jk.jpg
as you can see, the turbine has seen better days. both the turbine and compressor are not magnetic - that mean they are ceramic?. TT told me it had a ceramic shaft... looks and feels like steel to me and it is magnetic.
Any help identifying whether this is a hybrid or what's been done to it much appreciated. TT told me the compressor wheel and housing are standard but having done plenty of googling I have to disagree.
Bob I'd like to send it down to you as you seem much more cooperative and helpful that TT but at the same time I would ideally find somewhere more local where I can take it in and speak to someone face to face. I am off away this week so will have to put it on hold for a bit either way
The turbo looks stock apart from a bigger comp wheel.
It should have had a steel turbine wheel fitted at the same time as the comp wheel.
I would not clip the turbine wheel, you need as much drive from that as you can get for the bigger comp wheel.
The wastgate needs opening up to enable a greater flow.
mr2magic
Post by mr2magic »
The turbine surely isn't stock, bob.
bobhatton
Post by bobhatton »
mr2magic wrote:The turbine surely isn't stock, bob.
Looks just like a ceramic one to me and most upgrades do just use the stock steel turbine wheel and shaft.
mr2magic
Post by mr2magic »
Just take a ganders at the cast 'nut' on the turbine....every oem turbine i've ever seen has a 10 point, this one has only 6 ergo hex..
bobhatton
Post by bobhatton »
mr2magic wrote:Just take a ganders at the cast 'nut' on the turbine....every oem turbine i've ever seen has a 10 point, this one has only 6 ergo hex..
I see so many, I shall have to go and have a look and some.
2mad
Post by 2mad »
Not stock bob my blitz ct26 has 10 blades (turbine) and this one has 11 ..one of us has been modded 8-[
alex687
Post by alex687 »
yea the 11 blades doesn't seem to be stock looking at google images. Anyway I'll have to send it down to you bob and hopefully you can do some magic
bobhatton
Post by bobhatton »
alex687 wrote:yea the 11 blades doesn't seem to be stock looking at google images. Anyway I'll have to send it down to you bob and hopefully you can do some magic
We will find the right parts, never been a problem so far.
bobhatton
Post by bobhatton »
The turbine is the same as a steel replacment but the comp wheel is bigger as can be seen in this photo with the comp housing fitted on a stock wheel.
alex687
Post by alex687 »
bobhatton wrote:The turbine is the same as a steel replacment but the comp wheel is bigger as can be seen in this photo with the comp housing fitted on a stock wheel.
But all stock turbines i've seen only have 10 blades...
Is the compressor in good enough condition to re use?
bobhatton
Post by bobhatton »
Yes sorry I should have said stock size, it does have one extra blade.
The comp wheel has no damage so can be reused.
2mad
Post by 2mad »
Compressor looks a bit lost in the intake ... maybe go for something a bit bigger :thumleft:
alex687
Post by alex687 »
how do you mean? bigger than the one i already got? I thought it fit snug in the inlet?? and i was under the impression that if anything it was too big for the existing turbine...?
If you wanna speak on phone I might be able to talk this aft, if not then this eve.
2mad
Post by 2mad »
Dont want to cause controversy .. it just looks abit lost in the inlet 8-[
This is my blitz .. much closer to the intet housing ... Image
Not trying to be a dc1k just want you to get the best posable turbo :thumleft:
Happy to chat if you want to pm me your number .. not sure what more i can add though 8-[
bobhatton
Post by bobhatton »
2mad wrote:Compressor looks a bit lost in the intake ... maybe go for something a bit bigger :thumleft:
That is the bigger housing fitted to a stock comp wheel, the one that came with the turbo is bigger and fills out the housing ok.
The photo was just to show it does have a bigger comp wheel.
2mad
Post by 2mad »
Cheers for clarification Bob .. i was just a bit confused why a bigger compressor wheel was not fiited .. bags of space :thumleft:
alex687
Post by alex687 »
I got confused myself cos I didn't look at who was posting. I thought it was bob saying my comp wheel looked lost!
Whats the plan then bob? what parts need replacing? Can you get hold of an identical turbine wheel? would you recommend clipping it? and can you port the wastegate without too much trouble?
2mad
Post by 2mad »
alex687 wrote:I got confused myself cos I didn't look at who was posting. I thought it was bob saying my comp wheel looked lost!
porting the waste gate ... mega .. totally recommended it .. happy to post how i did it :thumleft:
alex687
Post by alex687 »
do it mate.. Not sure it's something I would have the patience to do myself hence why asking Bob if it's not too much trouble (and therefore my £££) for him to do it...
