![Sad :(](./images/smilies/icon_sad.gif)
Is there any advantage running the Power FC with just the base map loaded or am I best sticking with the stock ECU?
I'm running the usual bolt-on mods, charge cooler and 1.1bar on an EBC.
Cheers,
Mark
Chumbaside wrote:Is there any advantage running the Power FC with just the base map loaded?
Kongaroo wrote:The base map on the power FC is pretty good.The base maps were created using dyno time from what I read some time ago
- so they aren't just numbers somebody dreamed up and plugged in there for the heck of it.
But yes, obviously it's just to get you in the ballpark so get it mapped properly for the fuel you are running![]()
(and as Peter said
-leaving stock rev 3 ECU on is the most sensible option if you have stock injectors still)
