Dizzy Talk
rev3turbo
Re: Dizzy Talk
Post by rev3turbo »
elbon50 wrote:
All of those quotes are abusive & offensive Paul
I am a gentleman
I expect, and receive VIP treatment wherever I go
I do not tolerate abuse
And yes I speak my mind too
:lol: too funny #-o
elbon50
Re: Dizzy Talk
Post by elbon50 »
rev3turbo wrote:
I am a gentleman
:lol: too funny #-o
Not at all funny so far as I am concerned :!:
Peter
1989 MR2 Mk1 NA T-bar
1998 Ssangyong Korando GLS
2011 Honda Civic Type R
SuperRedMR2
Re: Dizzy Talk
Post by SuperRedMR2 »
Lighten up Peter.
If you worked in my office you'd find out what abuse was and Paul has not abused you.
elbon50
Re: Dizzy Talk
Post by elbon50 »
SuperRedMR2 wrote:Lighten up Peter.
I think that more than enough has been said on this thread Alex
I know the answer to my original question now
There is no Club conventional method for torqueing a dizzy
It seems that I may possibly be the only member who does that
So I shall say nothing more about it on here :)
Peter
tottacrolla
Re: Dizzy Talk
Post by tottacrolla »
PW@Woodsport wrote:It's a distributor bolt. :|
Yes it is until the aluminium threaded hole it goes into strips its thread because the bolt was over tightened then it becomes a total PITA.
If it is under tightened you risk a loose distributor and possible random ignition timing with potential for engine damage.
No reason not to set the correct torque on the bolts, plenty of reasons not to set it correctly.
If the OP wants to torque the bolts and asks about a tool to do it, why not just answer that question if you can, if you can't, don't reply. I'm sure he knows that it is possible to 'just nip up the bolts'
PW@Woodsport
Re: Dizzy Talk
Post by PW@Woodsport »
I did answer correctly, my Snap on £400 angled digital torque wrench fits perfectly in situ and allows them to be torqued, i also gave a method for doing it with a spanner and hanging scale which would be incredibly easy.
Neither were acceptable.
By the way, to strip the ally threads would take a force of well over 80nm, well beyond the torque you could achieve with a spanner.
This thread is ridiculous, only someone completely clueless would over or under tighten it, but hey i guess that is why the BGB has it listed, to make it idiot proof. :thumleft:
trunks_mk1
Re: Dizzy Talk
Post by trunks_mk1 »
going to high jack this now :)
I need to replace mine...dizzy cap and rotor arm...I have the parts. Can somebody school me how to replace this...method and tools, pics would be good. Couldn't find any in the search :)
thanks
User avatar
Lauren
Re: Dizzy Talk
Post by Lauren »
It's an 8mm socket IIRC.
Unplug leads, undo the two bolts. Take dizzy cap off. Pull rotor arm off. Put new one on, replace cap and do up bolts reconnected HT Leads which are numbered on the cap.
Pretty easy job really.
elbon50
Re: Dizzy Talk
Post by elbon50 »
I used the ring end of an 8mm open-ended & ring spanner to remove the two little setscrews that hold the cap Trunks
Not too difficult considering the relative lack of space around the dizzy on a Mk1 :)
Peter
trunks_mk1
Re: Dizzy Talk
thanks Lauran and Elbon :)
be doing it this weekend.
trunks_mk1
Re: Dizzy Talk
Lauren wrote:It's an 8mm socket IIRC.
thanks! done!
trunks_mk1
Re: Dizzy Talk
elbon50 wrote:I used the ring end of an 8mm open-ended & ring spanner to remove the two little setscrews that hold the cap Trunks
thanks! done!
