Steering rack
Steering rack
Are steering racks interchangable between turbo/NA aslong as you get one with power steering?
Re: Steering rack
Pretty sure NA and turbo racks are the same, but power steering and non-power steering are different.
January 2014
May 2015
Still in the garage...
May 2015
Re: Steering rack
Shmed wrote:Pretty sure NA and turbo racks are the same, but power steering and non-power steering are different.
Re: Steering rack
If it helps at all I'll soon have a steering rack out and for sale rev 3 power steering rack
Re: Steering rack
Im not 100% sure it is the steering rack i need just yet, i was just asking incase it is... The problem i have is that when i let go of the steering wheel after turning its not returning to central and just stays where it is?
Re: Steering rack
sounds like the steering rack to me.
Re: Steering rack
I thought so but all my suspensions abit screwed at the moment cus i crashed it lol so there could be something wrong there, how much you looking for, for your rack?
Re: Steering rack
Its still in the car and was working perfectly. I'll hopefully have it out this weekend so will be available next week. £70 collected or plus P&P unsure how much P&P will cost but can work that out once i've removed it.
Re: Steering rack
Sounds good i wanna get the suspension on first hopefully this week and see where its at then if i need it ill definatly have it from you
Re: Steering rack
Let me know.
Re: Steering rack
Draven wrote:Its still in the car and was working perfectly. I'll hopefully have it out this weekend so will be available next week. £70 collected or plus P&P unsure how much P&P will cost but can work that out once i've removed it.
That is a good price, the last mr2 i had had a receipt for nearly £300 for a 2nd hand rack, personally i was to lazy to remove it and it went with the shell
Re: Steering rack
chambers360 wrote:Sounds good i wanna get the suspension on first hopefully this week and see where its at then if i need it ill definatly have it from you
Could well be this, getting the kitcar on the road required steering to auto centre. If Toe out isn't correct on the front and tyres underflated it can make self centring more difficult for the steering.
Of course taking a whack could of damaged the rack.
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
Re: Steering rack
The self centering action isn't a function of the steering rack but is down to your suspension geometry (caster angle).
Re: Steering rack
Cheers guys, the car has apexi n1 coilovers on which are rock solid, it was apparently all set up properly from the guy who had it before me but its never centered itself since i bought it even before i bumped it, the wheel on the drivers side is now sitting further towards the rear of the arch than the one on the passenger side, ive had a look myself and couldnt seeing anything that was clearly damaged or bent so got my local garage to have a look on the ramps, they also said they couldnt see any damage.... So im thinking it could maybe just be the geometry thats causing the problem? Ive got new shock absorbers and spring to replace the coilovers with so once there on and set up hopefully the problem will be sorted? What do you guys think?
