[Mk2] [Turbo] crackstaft index(mark)for timing
Tomas_St
Post by Tomas_St »
Hey help again. Where is index(mark)on crackshtaf puller and up end block. I cant find
Tomas_St
Re: [Mk2] [Turbo] crackstaft index(mark)for timing
Post by Tomas_St »
thats damage or ....
mr2magic
Post by mr2magic »
Is this na or turbo? And what year?
Peter Gidden
Post by Peter Gidden »
mr2magic wrote:Is this na or turbo? And what year?
All the same except for BEAMS.
Peter Gidden
If you're in doubt, fit pulley, fit belt, fit lower cover and fit pulley. Then time cams in using outer marks on cover.
mr2magic
Post by mr2magic »
Peter, with all due respect - i don't require your help, the op does. So instead of answering my questions, answer his! I know the differences but after almost 15 years of messing with these cars and the problems that arise i have learnt to always ask the simple questions first , even if they seem stupid :wink:
Peter Gidden
mr2magic wrote:i don't require your help, the op does. So instead of answering my questions, answer his!
My most sincere apologies :roll:
So why ask an irrelevant question? If OP needs help, i learned many years ago to keep things simple and to the point.
Tomas_St
Post by Tomas_St »
its turbo rev2 1992
Tomas_St
Post by Tomas_St »
but we already did with cylinder pressure meter and head marks
mr2magic
Post by mr2magic »
It's certainly not irrelevant just because you deem it so. I realise you see yourself as a kind of mr2 god and I'm certain you know more than me and more than most..but that's no excuse for arrogance. Concentrate on helping the op and all is well.
bobhatton
Post by bobhatton »
Peter Gidden - SBITS wrote:If you're in doubt, fit pulley, fit belt, fit lower cover and fit pulley. Then time cams in using outer marks on cover.
This is what you need to do.
Rossi
Post by Rossi »
mr2magic wrote:Peter, with all due respect - i don't require your help, the op does. So instead of answering my questions, answer his! I know the differences but after almost 15 years of messing with these cars and the problems that arise i have learnt to always ask the simple questions first , even if they seem stupid :wink:
Wow, you've came across as a right xxxx there, precisely the reason I rarely post here. He answered both you and the op, your reply was needless, you were just having a go.
It's you that came across as arrogant, not Peter.
